Question about Seville Classics Dryers
The fan has stopped blowing it rotates and the lights are on but it has stopped blowing air
    Problem Solver:
  • 13 Answers
Try reversing the fan by using the switch or another chain in the cub. You might have accidentally reverse the fan
Posted on Oct 03, 2009
Lexus rx300 1999 not blowing air a/c
Check for power from the supply to the thermostat, to relay, to AC
Sep 12, 2015 | 1999 Lexus RX 300
Let's pretend you are an object. If you always saw the exposed side of the pictured fan, would you be the radiator, or would you be the engine.
This is not rocket science or law. this is auto mechanics. It has all been done a few million times a year before you. Please keep it simple! Find me and Randy helpful please. Youtube is your friend. lets-pretend-object-always-saw-exposed-u40lsvyytnuesyuv3fbafhtd-4-0.jpg
Jan 03, 2015 | 1987 Ford Ranger
I have the same fan bionaire btf4002 and it just stopped blowing air....the fan still rotates and all the buttons light up is there anything I can do to fix it
To fix your fan you have to unplug the power first then open the back cover by removing five screws, you will find a small black box under the motor direct has many wires (Red, white, Black, Brown, Blue & yellow) just connect the black wire to the brown wire as shown on the attached picture, the reason your fan motor is not working is that the thermal protection which inside the motor is broken so that there is no power go to the motor, by connecting the black to the brown wire you short that broken resistor, the thermal protection may broken just by the time not due the overheat. same-fan-bionaire-btf4002-just-hzleimpino4hjqoy1p2xeqp4-3-0.jpg
Sep 19, 2014 | Dryers
My gibson gas256q2a1 has stopped blowing all lights on panel are lite up but nothing is happening
Check fan relay, check manual fan switch, check fan capacitor, and check for correct voltage to fan if all is good motor is bad.
Aug 31, 2012 | Amana Heating & Cooling
My lasko fan stopped blowing air
The rotation gears have gotten clogged up, take it apart and put some grease or oil in the rotation parts/gears and work it in until it spins freely. Will work like a charge afterward. I had to do it once myself already.
Sep 24, 2010 | Lasko 2530 Elite WindTower Fan
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Oct 20, 2009 | Amana PTH153B50AE Air Conditioner
I need to replace my condenser fan motor. I replaced it once before but instead of blowing out the top, it was blowing on the condenser. Should it blow out of the top? If so, what direction should the...
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
May 08, 2009 | Heating & Cooling
The fun does not rotate
Hi!
Try to vacum the dust way from the fan, and try to blow the dust u cant vacum whit compressed air.
If that dosent help you need to buy a new fan. Be carefull so your laptop dosent overheated, the heat cam make big damages inside your laptop.
Good Luck
Nov 20, 2008 | HP Pavilion ze2000 Notebook
Fan will not work
open it. look for a wire that has become disconnected from careless factory assembly
May 11, 2007 | Lasko 2530 Elite WindTower Fan
Dryers Logo
1,254 people viewed this question
Top Seville Classics Dryers Experts
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
