Question about Simmons 510513 3-9x40 Blazer Riflescope - Matte Black
Problem the scope has moisture stains on the inside of the lens.
  • 10,515 Answers
Follow the below guide :-
http://www.telescopes-astronomy.com.au/telescopes061.htm
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 26, 2009
How to tighten loose front glass lens on pentax gameseeker rifle scope
You have to remove the front element carrier from the scope body and tighten the ring inside the carrier Now the funpart remove the thread protector then the gold ring making sure that the element carrier don't rotate while doing that Then count the rotations till you get the element out as that is important for the parralax free setup or you could just remove it and after repair reparrallax it your self YouTube has some vids on how to do that Threadloc the ring to hold lens tight inside the carrier reinstall carrier to maintube but you have to purge the tube of air and moisture to stop condensation inside the scope and fill with an innert gas Reparrallax scope if required and test zero
Feb 06, 2016 | Pentax Optics
I have a zeiss diavari 3-12x56 which has fogged up with water ingress after about 4 years on the rifle. I would have expected more from a so called high end scope. Any one else had a similar problem. ...
I would be persistent with Zeiss' customer service. Usually, high end companies will stand behind their product and make it right, provided that the problem didn't result from outright abuse.
Jul 11, 2011 | Zeiss Riflescopes Victory 312x56 T Diavari...
Fell into water, still can used, but got watermark inside lens.
You can use some absorbents to dry off the residual moisture but the marks might remain due to stain of the water. So try to use a hair dryer to warm the camera very carefully. Once there is no trace of water, but the marks remain on the lens , then it is important to remove the lens assembly after dismantling the camera so as to clean the lens using proper lens cleaner.
Attempt only if technically inclined and with proper tools.
May 04, 2011 | Cameras
Fogging up all time
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trash can size. You will need to get your hands on some nitrogen gas or you can also use carbon dioxide - even try nitrous oxide it should be easy to find at a sports store for paint ball guns . You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it sit and dry out. Now check for any o-rings and try to find new if you can, put the grease on the screw threads at the end of the scope. Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Feb 07, 2010 | Optics
My scope is fogging up on the inner lense not outer lense
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trash can size. You will need to get your hands on some nitrogen gas or you can also use carbon dioxide gas. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off of your scope, (This means unscrew it from the scope body) let it dry out a day or so. Now ck for any o-rings on the scope body some will have a small o-ring - like a good flash light the good metal kind, and try to find new if it has one if you can, put the grease on the screw threads. Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 11, 2009 | Bushnell ® Elite® 3200 3 - 9x40 mm...
My scope on my rifle is foggy on the inside
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trash can size. You will need to get your hands on some nitrogen gas or you can also use carbon dioxide gas. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out a day or so. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads. Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 09, 2009 | Optics
Rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 03, 2009 | Optics
I have moisture in my simmons red dot scope...How can I get it out I have disassembled it as far as possible and still can not get to lens.Model 851112
A red dot shouldn't be disassembled. If it has moisture in it, contact Bushnell (the owners of the Simmons brand now) at this site for warranty information.
http://www.simmonsoptics.com/ContactUS.htm
Nov 02, 2009 | Optics
I dropped my binoculars in the lake. What can I
use a butter knife edge the lens take it out clean it then put it back with super glue
Aug 24, 2009 | Optics
How to remove the corrector lens of a Nexstar 4
I would not try to remove the corrector plate-- the manual states to return the scope to Celestron if the inside of the corrector needs cleaning.
If removed the corrector has to be replaced in the EXACT position it was in before you took it apart-- the alignment between the front corrector plate and the rear mirror and the secondary mirror was done on an optical bench at the factory.
I doubt that will you notice or be able to see the small stain while you are observing--
Mar 15, 2009 | Celestron NexStar 4 GT (240 x 102mm)...
Simmons 510513 3-9x40 Blazer Riflescope - Matte Black Logo
48 people viewed this question
Top Simmons Optics Experts
james laughton
james laughton
ray gallant
Are you a Simmons Optic Expert? Answer questions, earn points and help others
