Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
The water is overflowing from the freezer onto refrig shelf
The water is overflowing from the freezer into the refrig shelf....the freezer drain hole is stopped up.
1. i can not seem to blow out the freezer drain hole with a small blower
2. i can't thread a thin wire thru the drain hole -
3. i have poured hot water in freezer drain hole but it is still stopped up and the water pools in one area at the freezer drain hole
4. there is no way to open back of refrig wo tearing back off - it is rivieted
any suggestions?
  • 20 Answers
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
Posted on Sep 26, 2009
Water leaking from freezer onto top shelf of frig. has to be wiped once a day.
You probably have a blocked or frozen drain hole in the freezer. This means that the water formed during defrost can't drain down to the evaporator tray beneath the fridge and instead goes through overflow holes into the refrigerator.
I posted about how I solved this problem in another post:
http://www.fixya.com/support/t8706684-water_leaking_inside_refrigerator
Mar 11, 2011 | Kenmore 64802 Top Freezer Refrigerator
Tip
What to check when your refrig. cools ok but leaks water from freezer
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
Gene
on Jul 31, 2011 | Refrigerators
I get puddles of water under milk and juice cartons. Sometimes the whole top shelf is a puddle of water. It is a glass shelf.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Aug 16, 2010 | Refrigerators
Water is dripping into the bottom of my fridge. I have cleaned and vacumned the coils. How do I access the drain to see if it is frozen?
Remove the ice maker and back panel in freezer.1/4 inch nut driver to remove screws. there are 3 screws for the ice maker 2 on the back wall and 2 on the bottom panel. Use a hair dryer to melt ice block.All water will flow down into drip pan under fridge. May overflow use a turkey baster to remove water from pan. Pour hot water onto drain until the water flows freely into the pan.
Jun 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
First thing this a.m. we discovered a puddle of water on the floor on the left side of the fridge. This is not the first time....so we are wondering what is causing this? I am guessing about the profile #...
You have a plugged defrost drain.
Unplug refrig. Unload freezer. Remove shelves. Take back panel out of freezer. Use a turkey baster with hot (not boiling) water to flush water in the area of the defrost drain hole until it is clear and water will run through it into the defrost drain pan under the refrig. The drain is a hole about the size of a nickel, usually in the very back center, below the cooling coils. You can use the turkey baster to force water into and eventually through the drain hole. Remove ice from floor of freezer.
Re-assemble, refill freezer, and plug in. Now, when your refrig defrosts, the water will go out the drain instead of onto the freezer floor and out the freezer door onto your floor.
Aug 05, 2009 | GE Profile PSI23NCR Side by Side...
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Kenmore Elite top freezer refrigator. Water is driping or somehow forming on the top shelves [under the top freezer] and a thin layer of ice will appear and the water contuniues to form. then over...
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 02, 2009 | Kenmore Refrigerators
My refrigerator has water inthe bottom under the drawersand overflows onto the floor. There is no drip pan underneath. I also have an icemaker inthe freezer and it dripa a little int the traybut that...
Nov 05, 2008 | Refrigerators
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
290 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
