Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Fridge walls very warm around freezer door - Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
  • 20 Answers
If the freezer is still working and keeping the food frozen, then this is normal. In previous years the freezers used eletric heaters for this and these days they use the hot gas discharge line from the compressor (more energy efficient), the purpose is to keep the door seal from freezing to the cabinet. If they didn't build it that way, you would really have to work for your dinner! cheers!
Posted on Sep 26, 2009
    Problem Solver:
  • 19 Answers
That is ok these fridges have the condencer lines within the walls of the fridge or some have heaters this is for condensate not to form on the fridge it keeps the fridge dry on the outside
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Excessive heat coming from bottom, and the wall
very repairable, the unit is tryin to release exessive heat from lower compartment, pull unit out and vaccuum the coils,as well as underneath the unit, when pulled away form wall, make sure that the fan behind the unit(next to compressor) is running.
Posted on Aug 25, 2009
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
Kitchenaid fridge, french door, bottom freezer. Freezer door was left open, now rails for ice bin remain frozen, difficult to pull out.
take the food out of the freezer,shut down the machine or just unplug it,get a hair dryer and hit the tracks and check the ceiling where the light is,usually ice builds up there to if the door was left open.also blow the air at the back wall,the air ducts could have froze up and the fridge will get warm,all it does is there's a fan in the freezer and it blows cold air from the freezer up and into the fridge section,sometimes depending on how long the door was open is the air ducts freeze and the fan can't blow the air up into the fridge,the tracks shold melt out fast then wipe them down but i would hit the back wall for a while until you don't see any water dripping down through the slots in the back wall,should take you no more than around 30 to 40 minutes to do this,hope this helps and good luck.
Sep 06, 2011 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
WE HAVE A BOTTOM MOUNT FREEZER PURCHASED IN LATE 2005 IT HAS BEEN A GOOD FRIDGE , EXCEPT RECENTLY I HAVE HAD TO DEFROST THE FREEZER BECAUSE THE FRIDGE IS NOT GETTING COLD . I HAVE NOTICED THE FREEZER IS...
if frost is on the back wall you have a defrost problem,bad defrost thermostat,heater or depending on your model a bad timer or board.also when you open the freezer door you should hear the evap. fan blowing around,this is what blows the cold air from the freezer to the fridge section.a common problem with bottom mount refrigerators is the door doesn't close all the way,warm air gets into it and then the air ducts freeze up and the fridge is warm.if this was the problem you would have ice on the ceiling,frozen water droplets on the packages and maybe ice on the top of the door where the air was getting in but if it's on the back wall it's a defrost problem.you have to remove everything out of the freezer,remove the door and basket,then remove the back inside wall of the freezer,either put the machine into defrost,if it has a timer advance it or if it has a board you can pull off the bottom kickplate and there should be a tech sheet,it will tell you how to put the machine into defrost,if the heater doesn't come on you'll need a meter to see what part is bad,also you need to melt all the ice off of the evap coil and check the parts.if you send the model number i can look up your machine and see what parts are in it and i can help you out better
May 23, 2011 | Maytag Refrigerators
My Kenmore Refrigerator is not refrigerating
if the freezer and fridge are warm check the start device on the compressor,alot of times you can smell a burning oder when this pops,also you can remove it and shake it,if you hear pieces rattling around then it's bad,also if there's ice on the back inside wall of the freezer then you have a defrost problem,also when you open the freezer door do you hear the fan blowing,if not you could have a bad defrost fan motor,open the fridge door,up near the ceiling on the right side you'll see the model number,send it to me,let me know if you found ice or frost on the back wall of the freezer or what you see and i'll be glad to help you
Oct 31, 2010 | Kenmore 53642 / 53644 Side by Side...
My fridge compartment is warm... frezzer ok, How do I check to see if the fan is operating and how do I check the vents
A refrigerator temperature problem like yours is likely due to one of the following issues. Open the freezer door and listen for the freezer fan, you might have to close the door/light switch to activate the fan. There is a vent at the top of the back wall of freezer, as well as a vent at the top back wall of the fresh food section. Wet your finger and place it in front of either vent and feel for cold air flow. If you dont feel any air flow in the fridge and the freezer fan is running, you will likely have a defrost problem, either the heater, the bi metal t stat, or the defrost control have failed. Any of these will result in frost on freezer back wall. YOu may also have a problem with the damper door in the fridge, again, top back wall, not opening, or on the rare occasion I have seen a slice of wrapped cheese on the floor behind the fresh food crispers covering the warm air return vent to the fridge.
Oct 06, 2010 | Amana AFD2535DES French Door Refrigerator
Fridge walls very warm around freezer door, fridgidaire
you may have a restriction somewhere, but i would definitely try to clean your coils, it is probably full of lint
Sep 26, 2009 | Frigidaire 20.3 cu. ft. / 575 liter...
My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | Daewoo Refrigerators
Freezer and Refrigerator Heating up
chances are the evaporator coils (behind the back freezer wall) are icing up and must be thawed out. this is from too much moisture freezing to the coils (door left open in hot weather, drain plugged, or fridge filled before letting it chill for a day empty and on). take back wall off and use warm water or a hair dryer (only until ice melts- do not overheat metal) to melt the ice. soak up excess water from under fridge, too. also check to see if the fan is working.
Jul 20, 2009 | GE PFS22SBSSS Stainless Steel French Door...
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
186 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
