Question about Kenmore Washing Machines
Set the load size to small and it fills up completely. I have a reset knob.
  • Kenmore Master
  • 2,605 Answers
Is the level switch positional, i.e. lo- medium- hi, or is it variable type switch? does it fill to the point of flowing over the top? You may have a blocked vacuum hose to the pressure switch, or it may be a level switch itself is faulty. You can test the switch for continuity if you can access it and have an ohm meter/ multi meter.
Posted on Sep 26, 2009
Whirlpool GSQ9669LW1 washer. Originally Load Size was set to small. After water was filled to that level and machine started to work, wanted to add more water. Turned the Load Size knob to Medium, nothing...
You would have to start the wash cycle all over in order to get enough water for the med load size. Once the washer starts it cycle you have to cancel that cycle to start a new one. Hope this is a help to your question
Apr 24, 2014 | Whirlpool Washing Machines
Load size dial won't set anymore, just spins freely
Most likely the knob is defective, order a new one.
Apr 25, 2017 | GE Profile WPRE6100G Top Load Washer
The load size knob just spins and doesnt select size of load large medium or small i think its set at medium so i can't set it at large or small
Pull the knob off and look at it. You will probably find that the knob is bad.Hope this fixed your problem.If not the knob then the switch is bad.
Jun 20, 2011 | Washing Machines
Not enough water
you have small,medium,large settings for load size some of the machines have a reset level by turning that knob all the way to the right and says reset check it out get back to me
Apr 08, 2010 | Kenmore Washing Machines
Washing Machine wont recoginze the load amount to fill with water, ex..small, med, it justs keep filling up to the brim??
Sounds like your problem is one of three things. Most common is that you have to "reset" the water level. This is done by turning the water level knob passed the large load size, and then down to small. Any time you want to go to a smaller sized load, you have to do this. Another possibility is that the pressure switch is bad, this is an easy fix (although not as easy as the reset) The switch can be purchased thru a local parts supply house. And the last thing could be a bad water valve. This will leak and continue to fill the washer after it is already full, this however is usually followed with water all over the floor. If it is not the reset, write me back and I'll walk you thru the other repairs. Hope this helps!
Dec 08, 2009 | Maytag Performa PAV2200
What does the ''Reset'' position on the ''Load Size'' knob do?
if you have filled machine to say small water level and change your mind you turn to reset and then set your new level hope this helps
Nov 06, 2009 | Coffee Makers & Espresso Machines
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
