Question about Kenmore Dryers
Kenmore Elite electronic control dryer intermittently works
Kenmore Elite dryer from 2000 worked fine until this past Spring, then began to intermittently only work on Express (high heat) cycle, all the while chirping in bursts of three chirps. Finally it quit altogether and I replaced the control board. Now, after about a month or two of working fine, it will act as though there is no power getting to the control panel, however I have checked the wiring and removed and reinstalled all the connectors onto the control board. It would not work, period, no lights no anything. Then after about three days it began working fine after not touching it during that period! It worked well for ten loads or so, then quit again. I went through the same deal, checked power, etc, but did not touch the control board or connectors this time, just let it set for five days, checking to see if it would start up again. It finally did and is running fine right now....what on earth is this about?
IFIXALL
  • 868 Answers
SOURCE: Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
Posted on May 22, 2008
djz83
  • 88 Answers
SOURCE: Kenmore Elite Dryer Problem Tub does not move
check your door switch
Posted on Jan 09, 2009
jumptrout51
  • 3361 Answers
SOURCE: replaced bad high temp sensor and two loads later it is bad
It will continue to blow until you correct the blockage in the vent system.
It may be internal to the dryer or external to the connecting vent or outside vent.
Find it and fix it.
Posted on Mar 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Everything is fine, except it
Hi Ron. I just lost a very extensive reply to you. Yes it can be the pulley making the chirp or the drum rollers. Items 15 - 18 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172907&diagram_id=1356738#d1356738
It can also be caused by dry drum rollers but usually this is associated with a rumble: Items 2, 11, 12 and 13.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172907&diagram_id=1338080#d1338080
Thanks for choosing FixYa.
Kelly
Posted on Aug 18, 2010
BElectric
  • 1140 Answers
SOURCE: Dryer does not start. It is model LER7646EQ1. I
This sounds like several faults rather than one, but the likely original cause is the thermostat. Thermostats most often fail in the closed (on) position which would mean that the element was always on, rather than switching on and off when your dryer reached the correct temperature. This would explain why the control panel seemed hot.
This also explains why the dryer was stopping during the cycle. Your dryer is fitted with a thermal-fuse which trips and cuts power when the dryer gets too hot. However, a faulty thermostat doesn't usually stop the dryer running. A broken thermal fuse usually will.
From your description, I'd say you are definitely going to need a new thermostat, but I doubt if that's the only part you're going to need. You may well need a new thermal fuse and as the control panel got hot, this could have been damaged also.
I wouldn't buy any parts until you've inspected the control panel. You really need a service manual . but they are not usually available free. Failing that you're going to need some test equipment (Voltage & Ohm meters) to find the problem but if you don't know how to use them, it's definitely time to get an engineer.
I wouldn't advise buying any parts until you've investigated thoroughly - unless you can get them cheaply and return them if they aren't needed.
Posted on Oct 18, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
The control lock button is light up and the washer won't work.
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 23, 2010 | Whirlpool Washing Machines
How do i get the control lock button to turn off?
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Kenmore Elite Dryer only runs if hold Start Switch
sound more like a control board failure // if it has one,, maybe the belt, starting switch
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
New Machine Control Electronics needed?
HUH????? just change interface(buttons and board ) have never took time to ck resistance.. front interface just tells machine control what to do
Sep 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer - Model No. 110-85872401
hi thanks for the question i would check the door switch open the door and at the top right you will see a small metal piece sticking out that sometimes bends and don't always make contact check that the appliance doc
Jul 10, 2008 | Kenmore 63942 Dryer
May 21, 2008 | Kenmore Dryers
Dryers Logo
158 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
