Question about Panasonic PV-DV200 Mini DV Digital Camcorder
No audio output to computer
I recently used an external mic with my Panasonic PV-DV200 camcorder. It recorded fine - when I play the video back in the camera I can hear the audio. However, when I try to upload it into my computer, the video uploads but there's no sound. I tried changing the VCR Play Mode - Audio setting to ST2 and MIX, but it still doesn't upload the audio with the video. Up until now, I haven't had a problem so I figure it must be something to do with the way the audio is recorded with an external mic. Any ideas? Thanks!
  • Anonymous May 23, 2008
    samee here :( waaah...
  • paulgsmg Dec 31, 2008
    I have the very same problem. When I import it to my computer, the audio does not come through my computers speakers. Although, when I plug in to my headphones or external speakers the audio does come through. This only happens when I use the external mic.
SOURCE: Panasonic PV-GS31 video to PC trouble.
The usb is only used for the still pics and for the webcam. You need a DV cable to upload vid.
Posted on Sep 24, 2008
SOURCE: uploading a video
use a fire wire cable
Posted on Oct 04, 2008
  • 383 Answers
SOURCE: can't upload my videos from my Panasonic PV-GS29 to my dell compu
usually tv capture cards can help you .... just check for a external TV tuner card with capture facility
Posted on Dec 07, 2008
SOURCE: I purchased a Panasonic SDR-H40P/PC
Good Cam
Posted on Dec 21, 2008
SOURCE: Upload content from PV-GS65 to LAPTOP
there should be a usb port on the camera. below the mic in, under the flap to the right of the on/off.
should be able to get this cable at any office supply/ camera store.
Posted on Jan 19, 2009
I own a Panasonic PV-GS31 Mini DV Digital Camcorder, I am a Private Investigator and while recording the sound needs to be muted, how can I accomplish this?
Hi There, There is no external mic input on that model camera. The only way to do it is you will have to take the front panel off the unit and disconnect the flat mic/audio cable from the front panel. If you do this, tape up the connector so it won't short out the unit. If you had external mic in, you could put a dummy plug in and that would cut the sound from the internal microphone.
Thanks, me cicmo
Dec 02, 2008 | Panasonic PV-GS31 Mini DV Digital...
Camcoder (Panasonic PV-GS15) does not play back recording
Sorry to say- but it is trashed.. It would cost more to fix it than it would be to buy a new one.
May 06, 2017 | Panasonic NV-GS10 Mini DV Digital...
Turn the sound off for recording on PV-GS320 DV camcorder
Hi, I think the PVGS320 has an external mic input. Plug in a 3.5 mini dummy jack and that should turn off it internal microphone.
Nov 15, 2008 | Panasonic PV-GS320 Camcorder
Input audio to PV-GS250 from an external mixer
Problem check list:
- Try another cable in the connection to rule out the cable
- Make sure the 1/8 plug goes in all the way
- Make sure you have it connected to proper outputs on the mixer (and that it's not a powered mixer!)
- Make sure you don't have the output volume up too loud on the mixer
Dec 01, 2007 | Panasonic PV-GS250 Mini DV Digital...
if it has a external mic jack you could see if that is working. if it is then the mic on the camcorder is bad.
Sep 15, 2007 | Panasonic VHS-C PV-L354 Camcorder
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Broken DV port
I sugust you get a capture card with rca jacks and a line in converter cable and use the cards capture software to record from camcorder to computer and then use a editing software to output to dvd or vcd for playback the 2 programs I use are pinnacle studio 10 plus and ulead dvd moviefactory for output to media. then if you wish you can get the camera repaired so you have got firewire port back or dv port as its known. good luck on this one
Nov 23, 2006 | Panasonic PV-GS39 Mini DV Digital...
Built-in microphone does seem to work
The only way to really tell if the buit in mic. is bad is to replace the mic or plug another one in the external mic. jack. Also use the input (red and white) RCA jacks and input a signal from a stereo or TV into it and record. If still no sound then its probably Bad capacitors in the sound processor Printed Circuit board. Sorry to be the bearer of bad news but mostly all of older camcorders suffer from this breakdown fault. Good luck
May 21, 2006 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic PV-DV200 Mini DV Digital Camcorder Logo
49 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
