Question about Refrigerators
I have a fridgedaire side by side gallary series ,icemaker gets no water in tray and supply line to tray pops off and spills a little water be hind refridgerator.Whats wrong ?
    Problem Solver:
  • 19 Answers
It could be the water pressure or it can be the water solinoide at the base of the fridge
Posted on Sep 26, 2009
    Problem Solver:
  • 5 Answers
Water valve the on back underneath right side it is dual valve one for water in door other for ice you probem is calcium from the city water needs replace or cleaned then filter water going into valve
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
No water in icemaker
Please click on the blue links which are underlined to get more info.
Here are the check's which you can do:
Goodluck..
Feb 19, 2008 | Frigidaire FRS26F4C Side by Side...
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
Fridgedair R134a ice maker water wont fill. Solenoids & valves are good & water supply lines good. Im works fine. So, where does the signal to the IM solenoid & valve originate from. I already...
Your icemaker send the voltage to the water valve as it cycles through its ice drop. Pull your icemaker out, and test the wiring it was plugged into for continuity to the water valve, usually you will only have one colored wire that has continuity. Your white wire is usually your nuetral and as long as both wires are ok, then replace your icemaker or your icemaker module if it has one. You have a very good parts house on Oahu called Reliable Parts, Take your icemaker in if you live on Oahu, or call them with your parts number if you are on the Big Island. I worked on Oahu for 15 years. Good Luck Appliance Specialists
Dec 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigedaire icemaker problem. Water line, maybe.
Did you turn the water back on? Pull the live off the back of the fridge, put it in a bucket and have someone hold it. Then go open your water valve for about 10 seconds. That will at least tell you if water is getting TO the fridge.
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
I have a coldspot kenmore
Tim,
At first blush it sounds like the water valve that supplies water to the ice maker is sticking or leaking and letting too much water in.
If you can, watch how much water fills into the ice maker tray (very boring stuff). If it overfills the icemaker tray, then the water valve or timer is malfunctioning and needs repair or replacement.
Apr 08, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice trays not filling with water
I know where the solenoid is, my question is I have water pressure into it, but not out of it, no warranty, trying to fix it myself, is this the probable cause of my problem, or could it be something else? I can hear what sounds like water running near the ice tray,but can't figure out where it is, also, when I recently filled the fresh water holding tank, it spilled over inside before spilling over exit tube of holding tank. Is this connected?
Mar 26, 2009 | U-Line Icemaker
Ice frozen together
you can adjust the amount of water by popping the front white cover off the icemaker and adjusting a screw . depending on the model the screw will be a flat head on the side of the icemaker or a phillips screw on the front of the icemaker.
Aug 17, 2008 | Viking VCSB423 Side by Side Refrigerator
No Water in Ice Maker???
could be a limescale problem blocking line,or solenoid falure,
Jun 23, 2008 | KitchenAid KSRB25FKSS Side by Side...
Something is wrong with my icemaker
check supply tube behind ice maker,make sure it is lined up to feed icemaker,also you can pull it out look inside to make sure it;s not frozen inside tube or frig. wall,thanks-mike
May 28, 2008 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
