Question about Ingersoll Rand Ingersoll-Rand 1/2 in. Drive Impact Wrench
My ir 223 impact trigger doesnt work ,,,I took it apart ,the pin tha goes thru the body is there but the pin in the airlet is missing and it must be missing a spring too ,it just wants to run wide open all the time ,,Are there manuals and parts available for this tool ???
  • 72 Answers
Did you get it fixed? Mine is doing the same thing, don't know what to do. What did you do and did it get fixed?
Thanks.
Alex matzie323@yahoo.com
Posted on Nov 11, 2012
    Problem Solver:
  • 16 Answers
You can purchase a repair kit from Ingersol that will have the spring and pin. You will need to make sure the fitting on the inlet that has the screen installed is still there or the pin and spring will come out again
Posted on Oct 12, 2009
DeWalt D51823 nailer leaks air and shoots continusously
Common problem with dewalt due to vinyl orings. Simple tests to determine if trigger valve may work before re-installing. With trigger valve in hand, depress the trigger pin and hold. The bottom of the inner spool is visable in the opposite side from trigger pin and should move inward slightly with little effort when you push it (spool should have almost no movement inward before making contact with body of valve ). If the spool moves inward 1/16 to 1/8 inch, most likely the oring is too worn and not making contact with body of valve (when under pressure, this spool is held against body of valve (closed), and will open when pin is depressed (firing pin pushes on the spring and spring pushes open the valve) ). Next take valve apart and pull out the spool (spool should be difficult to remove from lower body of valve). With spool in hand push upper part of spool into the cap, should fit snuggly. trigger pin has two orings. The upper oring should fit snuggly into cap and lower oring snuggly into spool. The two orings on the pin are made of vinyl and fail. Notice that the spool has a small hole at the bottom. If the pin oring s bad air will leak past pin. Replace with 2mmx1.5mm black oring. After replacing the two pin orings, make sure the pin fits snuggle in the cap and spool, if not , replace the whold valve. The spring is usually good, but if rusty, replace the whole valve unless you happen to have the exact spring in good condition. The two outer orings on the body of the valve do not have to be replaced unless cut. Good luck
Dec 23, 2012 | Air Tools & Compressors
Model number 223
IR 2135-k303 air inlet repair kit along with a 2131-322 air inlet removal tool should get it repaired.
Nov 12, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
Hello, there is air coming from the trigger area, I suspect there is some kind of o-ring or some kind of seal broken where the trigger goes into the piston area, I just want to know how to take that apart...
Trigger valve is part number A08368 or (old part #897458). Easy repair. Remove air supply hose, and nails. Remove pin holding trigger to expose trigger valve. Spray soapy water on valve to determin if air is leaking from outer part of valve (orings that contact the body) or around the pin. Remove roll pin/s holding trigger valve in body of gun (use 3mm pin driver, some guns have one pin others 2). With pins removed, apply air pressure to gun and valve will pop out (use heavy glove or rag in hand to catch valve because some valves come out with force). With trigger valve in hand notice the two groves on sides of valve that roll pins contact (when you re-insert valve align valve so groves align with roll pin in body). Remove the two pins holding inner workings of trigger valve. There are two orings on the trigger pin, three orings on the inner valve and two orings on the outer part of body of valve. Usually, the orings that cause leak are the two smallest on trigger pin and three on the inner valve (unless soapy water test indicates outer orings). Orings are available at dewalt service center by part number or if you like to tinker, Lowes has many usefull orings in the plumbing department or replace the whole valve for about $25. Use plenty of silicone paste lube on the orings (sold at lowes). Valve should press in without a great deal of force and be sure to align valve to roll pin in the body. Use 3mm punch to temp. hold valve in gun for test. Good luck
Mar 28, 2011 | Porter Cable Cable No. FR350A Rnd Head...
Model 734 1/2 in impact.wont blow air ,wont rotate,no tension on trigger.feel like problem may somehow be in trigger housing....
Yes, if you take it apart you'll find that the trigger isn't allowing air to pass through to the veins of the impact wrench. It's a relatively simple mechanism, where maybe something is broken inside.
If it were blowing air but the veins were stuck, I would say, lubricate it. But, if no air goes through it at all, then the trigger housing houses the problem part.
Have you tried to disassemble the air wrench?
Jan 21, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Missing parts
The rebuild kit #295A-TK2 has all the parts to bebuild your existing model. The includes a new plunger and spring plus all seals and vanes for this model. Any IR dealer can get this for you.
Jan 16, 2010 | Ingersoll Rand 1? Heavy-Duty Air Impact...
I have a ir 5/8 drive impact #2905vw599 and need parts
the best advice i can give, after being involved with rattle guns for 30 years is for you to take it to an air tool service centre , ithink the main parts you will need willbe o rings and they will have access to the parts required ,even if they be after market, believe me ,that is the way to go .
Nov 11, 2009 | Air Tools & Compressors
Need repair diagram ir 2135ti want to reassemble trigger for 1/2" 2135ti
try going to irtechpubs.com nd under industrial tools you will find your model number and can download a breakdown for it. Let me know if you have trouble, I went thru about 15 sites before I found it.
Nov 02, 2009 | Ingersoll Rand 2135Ti Air Impact Wrench
Lack of power
the golden rule from i/r ,shinano,and all the air rattle gun manufacturers DONT USE WD 40 OR ANY OF PENATRINE TYPE PRODUCTS.for preference only use auto trnsmission oil if you arent prepared to buy air tool oil. If you brought the tool to me for a diagnosis and or repair,I would tell you that there is a small neoprene O/ring up in the trigger area that gets hard and starts to break up,giving those exact symptoms. those kero based products spoken about, exacebate the problem and often are the cause of the O/ring be coming hard in the first place.my recommendation is to take it an airtool service centre ,it wont cost all that much(australia about $75 give or take) I agree with the dog ,good tools are worth looking after.No offence meant, just many years of experience
Aug 16, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Just blows air when trigger is pulled.
Dave The rotor is too tight on the plate. Tap shaft with fiber mallet to open the clearance
Apr 07, 2009 | Impact Ingersoll-Rand 1 Inch Heavy Duty...
Ingersoll Rand Ingersoll-Rand 1/2 in. Drive Impact Wrench Logo
593 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
