Question about Vizio P50HDTV10A 50 in. Plasma HDTV
TV does not respond to remote commands,
TV does not respond to remote commands until the command given again and again or you are standing immediately in front of the TV.
    Problem Solver:
  • 14 Answers
I'm sure you've tried this, remote batteries is most common cause.
Make sure sensors on TV and remote are unobstructed(remote only works if line of sight to sensor is clear) and clean. Windex and Qtip. Damaged/dirty/defective remote, try different if possible (universal). If none of above works(99% chance), extreme longshot is TV circuitry.
Posted on Sep 26, 2009
I have a jvc LT42P510 tv and it is hooked up to a Dish Network 722k hi-def dvr receiver, the dish remote will not function in the dish mode, for example when the dish receiver is plugged into the tv using...
hi,
Check the version of the hdmi cable you used. Try to use hdmi cable version 1.3 or above . Also try hdmi cable with version 1.2 .Version of the cable is very important one.
ok
Mar 04, 2011 | JVC LT42P510 42 in LCD TV
I NEED A NEW REMOTE CONTROL
Hello
I thinks that you need a new universal remote control for your RCA tv, and answers. You just buy one stated below,and codes and other proceedings are also given.
Model No: [RCA - D770 Wide Range Remote Control]
Codes for RCA TV with this remote control are:-
1000, 1003, 1004, 1005, 1006, 1007
.........................1019, 1096, 1098, 1099, 1100, 1101
.........................1102, 1103, 1129, 1179, 1181, 1187
............................................1188, 1190, 1198, 1199
Proceedings
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn't, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
NB: Switch Off and On your TV with its front panel power switch each time [NOT BY THE REMOTE CONTROL HANSET], before you try an other code, UNTIL YOU GET THE RIGHT ONE.
Dec 20, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Turns on, but buttons don't respond.
If you have a remote,just press down on the volume up button and roll it around in circles.It sounds stuck and that sometimes will help unstick it.Also do it on the TV's button.If that doesn't work please let me know and we'll try something else.Good luck!
Aug 01, 2010 | Polaroid FLM-3232 Television
I am trying to get my philips universal remote to workcr with a sony dvd/vcr player..how do i do it?
please go to the below website and select the model of your remote.
An page opens in that you have REMOTE CONTROL CODE FINDER,click it
Choose the device type and device make it gives the code for your remote.
Then follow the procedure given below,
1 Turn on the DVD ( The DVD should play ).
2 Select DVD on the remote (= Press the device key for which you are programming the remote ) :
keep the key pressed for 5 seconds until it blinks twice and then remains lit.
3 Enter the given four-figure code for your brand , using the digit keys .
– The DVD key will now blink twice and then remains lit.
• If the DVD key blinks once , the code has not been entered properly or
The wrong code has been entered. Start again from step 2.
4 Press and hold the “ standby/power on” key and immediately release it when the TV
switches off (standby).
– This may take up to 30 seconds.
5 Turn on the DVD and check if you can
operate all needed functions on your DVD
– Make sure the receiving device is able to respond and accept the desired command .
6 Press the DVD key twice to exit setup mode and save your settings.
– When no key is pressed for 2 minutes or more the remote control
will exit setup mode automatically.
• If the device does not respond at all or not to all of the key commands or if you cannot find
the code for your brand, enter ‘0, 0, 0, 0’ in step 3 and continue with step 4.
The remote control will now search the full database for a code that works with your DVD
Full database search may take up to 15 minutes.
thanx
Jul 21, 2010 | Universal Remote Control Hampton Bay...
Programming the remote to my tv do not no the tv code
The code can either be automatically found or you can look it up online. To automatically program it follow these steps:
Turn on the TV, and then point the remote control toward the TV. Then press and hold the TV button and the OK button at the same time for two seconds. Then all of the buttons will light up for two seconds, then only numbers 1-12 will stay lit.
Then press the CH+ button to send a series of off commands to your TV. Continue pressing until your TV turns off.
Note
Give enough time for the TV to respond to the off command after you press each button. Some TVs take more time to react to off commands than other TVs.
Press the TV button to save the code and to exit. All the buttons on the remote control will blink three times to confirm the code.
If this does not work then repeat the steps up to the point where the 1-12 buttons light up. Then go to this site and find your TVs code, there will most likely be a few codes for your TV, try each one until one works:
http://www.maxconsole.net/forums/archive/index.php/t-13852.html
After you enter the code, press CH+ again until your TV turns off.
That's it, you shouldn't have a problem anymore. Good luck.
Feb 13, 2010 | Microsoft Xbox 360 Universal Media Remote
Touch screen not responding to any commands
I tried the 2 solutions i was given but it still didn't fix the problem, I ended up calling logitech tech support and they advised me to install the software and download new programs for the remote, after about 1/2 hour and recalibrating the complete software/ firmware the problem was fixed.
Mar 19, 2009 | Logitech Harmony 1000 LCD Touchscreen...
I need codes for a rca d770
Programming For TV
commands. If it doesn’t, try pressing the device button
Emerson ..................1004, 1006, 1012, 1014, 1023
..................................1024, 1025, 1026, 1027, 1028
..................................1029, 1030, 1031, 1033, 1034
..................................1035, 1036, 1038, 1039, 1041
..................................1042, 1043, 1044, 1046, 1047
..................................1123, 1124, 1162, 1171, 1176
......................................................1177, 1179, 1191
Your user manual is available for download and option printing at the following link :
http://www.retrevo.com/s/RCA-D770-Universal-Remotes-review-manual/id/402ci568/t/1-2/
May 16, 2008 | RCA D770 Remote Control
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
584 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
