Question about Boating
Minn Kota Deckhand stripped gears
I have a deckhand 40 and it seems the gears are stripped. The weight falls free and when attempting to raise weight nothing happens. I took the cover off and the line spool spins free and a small metal pin fell out. When I looked at the pin it appears to have a broken edge on in and there is a rubber flap attached to it.
Is there a replacement part availailable and if so, how tough is it to install?
  • 76 Answers
Hello!
Here is a schematic for your Deckhand:
DH40
The install of the large plastic gear is fairly easy if you are somewhat mechanically inclined (you must be if you posted the question ;)
Give it a go, last one I did took about 20 mins.
Mike
Posted on Sep 26, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn Kota deackhand 35 won't lift a 28lb anchor
    How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
    Sep 29, 2015 | Minn Kota Boating
    Anchor will not go down but will go up
    I have two deckhand anchor units. I ve tested both on battery, and both went up. I replaced switches, and I get nothing, but I heard a light click coming from unit. Is the motor bad?
    Nov 09, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    Anchor pulls up won't release to go down on either of the two switches
    Im getting power to motor, but can't get it go down. When I hit switch I can hear a clicking sound from the unit
    Nov 05, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
    The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
    Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
    I HAVE A MINN KOTA DECKHAND 35 THAT WONT WIND UP. IS THERE A GEAR I CAN REPLACE?
    Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
    I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
    Good Luck!
    Jun 09, 2009 | Boating
    Minn Kota electric motor MKJI1033962
    Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
    800-227-6433 they will help you with any technical questions.
    Parts can be purchased from this dealer...There are schematics on the site for review....
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    =100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
    Aug 10, 2008 | Minn Kota 40 Edge Bow Mount With Hand...
    Boating Logo
    323 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
