Question about JVC HD-56FB97 HDTV
Red temp and lamp light flashing - JVC HD-56FB97 HDTV
  • 456 Answers
You may need to replace the lamp in the unit, to do so, remove the lamp and if it sounds like a rattle inside when you shake it, its blown due to heat ,hence the red temp and lamp warning. after replacing the lamp make sure you reset the lamp use hours. good luck.
Posted on Sep 26, 2009
Optoma hd73 the temp light is red and wont start fans or light just the standby light on flashing could this be a ballast issue or thermal sensor?
if you projector auto shut down, and Lamp LED Light - Check Lamp - Check Lamp Driver - Check Main Board b. Temp LED Light - Check Thermal Sensor - Check Thermal Switch - Check Fan
May 12, 2016 | Office Equipment & Supplies
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Tv will not power up blue power light flashing,red temp and red lamp lights flashing
The lamp is likely blown - it is loacated behind the front panel and can be pulled out to check - unplug set and do not touch front of lamp.
Oct 11, 2009 | Hitachi 50C10 LCD TV
TV went off, and three lights come on (green "power", red "temp", and red "lamp")for just a second, in succession from left to right.
My television had two red lights flashing, one for Temp and the other for the lamp. I removed mythe lamp assembly and the bulb filament was burnt out. I order a new lamp and housing unit UX21517 and replaced it and now I have the red light flashing which is calling out the lamp again.
Oct 10, 2009 | Hitachi 50V720 Television
LAMP LIGHT ON AND TEMP LIGHT, TELE WILL NOT COMME BACK ON
Look in the owner's manual. These lights indicate the current condition. Usually the lamp light will go on if the lamp has failed and similarly the temp light if the fan has failed. With both, there may be a different problem. If you can confirm your model number, I can look up the problem indication as well.
Thanks,
Dan
Aug 25, 2009 | Hitachi P50S602 50 in. Plasma TV
Hitachi 55" when I turn it on the screen is blask and no sound.
first step to take:
refer to the user's manual to find: How to replace the lamp?
and second replace the lamp. www.andrewselectronics.com. prefer original ones.
Mar 29, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
JVC HD-56FB97 HDTV Logo
447 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
