Question about Fujitsu LifeBook T2010 Tablet PC
My laptop turns off when it is not plugged in. Battery doesn't charge fully. Have replaced the battery - same result
    Problem Solver:
  • 6 Answers
It is probably the "Powersave" function that turns off the machine when it is only on battery power and is not being used for a certain length of time. Also if the batteries are not charged properly, the laptop will want to shut down as the power level is becoming critical. So there are two possibilites 1. change the Powersave function and/or 2. drain the batteries entirely and re-charge fully before using them. I have found that batteries work better when they are used entirely before recharging them, so I actually have the Powersave function turned-off. There is probably a Fujitsu Powersave facility that is integral to the laptop, in addition to the Windows one, whether the Fujitsu one controls the Windows one, I'm not sure.
Posted on Sep 26, 2009
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
Apr 30, 2015 | Tablets & eReaders
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
Tabeo tablet battery not charging will work if plugged in
Hi! Hope this may serve as a hint. When power problem dooms to any electronic device needing battery operation we sometimes least assume that the battery life is near to its end. I mean its charging life has come to end. However, you can sometimes recycle it's life cycle by discharging fully and recharging fully without using it. Battery utility softwares can help monitor its life but cannot revive at all. Charging also using fast charger and or slow charger can help reactivate the battery cells. I personally experience, a gadget of mine its charging life is almost come to end and when I accidentally plug it on my laptop with 3.0 USB offline charging capability it somehow raise its life but not as good as it is. If the above doesn't work at all, it's time to change the battery pack. Goodluck!
Mar 09, 2014 | Toys R Us Tabeo
After charging my lindle on my laptop i cant switch it on
Try charging it with the electrical wall plug-in.
I read in some Kindle reviews on Amazon that charging through USB ports on a computer doesn't always work.
Did you get a green light that indicated the battery was fully charged?
Dec 26, 2011 | Amazon Kindle 1
How to discharge battery
"Calibrating" a laptop battery is one way to increase the lifespan of a battery that doesn't last long. The procedure involves two steps: fully discharging the battery, then then fully charging it immediately thereafter. It's important to note that a full discharge doesn't mean you drain your battery until your computer powers off, but rather that you deplete it until it reaches a level of approximately 3 percent capacity, according to BatteryCare.com.
1. Charge the laptop battery to 100 percent. Allow the laptop to sit plugged-in and fully-charged for approximately two hours.
2. Click the "Battery" icon in the lower, right corner of the Windows Taskbar and click "More Power Options." Click "Change When the Computer Sleeps," then click "Change Advanced Power Settings."
3. Scroll down to "Battery" and click the "Plus Sign" icon next to it. Click "Critical Battery Level," then click the arrow to decrease the number to "3." Click "Apply," then click "OK."
4. Unplug your laptop and continue using the computer until it reaches 3 percent, at which point it hibernates automatically. Allow the computer to hibernate for at least five hours, then plug it in and allow it to recharge fully.
I hope you find it very helpful. Thank you for using fixya.
Aug 17, 2011 | eMachines eM3502074 Tablet PC
When I go to use wi-fi, it keeps saying wi-fi is disabled. Yet, other laptops in the house work off the wi-fi
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Aug 01, 2011 | Acer Tablets & eReaders
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Fujitsu LifeBook T2010 Tablet PC Logo
216 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Tony
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
