Question about iRiver Clix Digital Media Player
Frozen Screen - Won't Reset
I finally dug this thing out of the bottom of a drawer in an attempt to sync some songs. After all of the songs had appeared to be synced, Win Media Player got stuck on "Sync in Progress" or whatever, and wouldn't finish syncing. So I unplugged it, and it got stuck on the main screen reading, "iriver clix." So I reset it, and it just goes to the same screen. Every couple of minutes, it goes black and then back to the "iriver clix" screen. Nothing will change it. WTF do I do?
  • 1 more comment
  • boomerisgod Jan 05, 2008
    I was playing a flash game. It got stuck on the title screen, and I can't reset the system, or do anything else even though my files work and have not been affected.
    It's just frozen on the title screen... any tips?
  • Anonymous Feb 21, 2009
    like ten minutes before i had a bunch of things on it . but then i turned it off but when i turned it back on it stays on the same screen and it just says iriver but it wont do anything. i tried to reset it but it goes back to the same screen.
  • Anonymous Mar 22, 2009
    I have a 2 gb iriver clix digital media, but it is not get charging or power on.
Something a little different happened to me, but I fixed it.First, the problem: As I was recharging it, I bumped the iclix off the desk and it fell on the floor. It was fully charged and I didn't think anything of it. The next day, I turned it on, and it just stuck at the title screen, and would not turn off. It also didn't respond or do anything when I plugged in to connect it to WMP. It is probably just over a year old, so beyond the warranty.
Proceed at your own risk....and doing this voids the warranty. I took a swiss army knife and carefully pried the back (white side) panel off, lifting at a corner first. Then I took a table knife and lifted the battery out, which is taped or stuck in a little bit. You have to be really careful doing this as the battery metal is soft and distorts easily. Also, lift the battery from the end where it isn't attached to the two wires. Then, I touched the table knife to the metal lines on the circuit board and caused it to shut off, thereby reseting it. Nestled the battery back in place, snapped the back in, and it works like new. In fact, it works like it did when I got it, as for the past few months, it hasn't been remembering my last track, but now it does.
Whew! What a relief I don't have to buy a new one, because I didn't want to go through the hassle of getting this repaired, nor did I want to buy a new one, because I liked this one a lot. My theory was that the jolt from the fall, while it was connected and recharging, caused it to freeze the internal software, or something.
I think tex1084 has a similar problem and might try this, if let's say, your warranty is gone, and you've already bought another. I almost threw mine away, and boy I'm glad I didn't!
Posted on Jan 11, 2008
  • MrIntuitive Jan 12, 2008
    To add to my post, which after thinking about, I was going to amend or delete.
    Lithium batteries are VERY toxic. On the minor chance, yours may be leaking, and that is what is causing the problem, such as a leak onto the circuit board, do not touch or handle the battery!!!. Even if it is fine, you should wear plastic gloves, and if you see any kind of leak, don't try to fix your iclix. When I mentioned "sticky" in my post, I just meant from some little pieces of tape that are at the sides of the battery, not from any kind of leak.
    However, the battery in the Iclix is not like the lithium battery in a camera or an easily replaceable one. Instead, it is soft (like thick foil almost) and not meant to be handled, except by service people.
    I didn't see any leak in mine, but the more I thought about it, the more I thought of the danger of puncturing the battery, because the metal case of the battery is so soft. Plus, some malfunctions could be caused by a battery leak, and if yours is leaking, you really don't want to get into trying to repair it yourself.
KitchenAid KBFO42FTX04 bottom drawer frozen shut.thawed but refreezes in 3 hours.Ice crystals everywhere.Icemaker off.How is it freezing shut?
Your freezer drawer is not sealing 100% and room temp. is entering and causing your winter wonderland. The freezer drawer rides on two rails and these rails can get out of sync. One way to correct alignment issue is to open drawer all the way with a little bit of force. Next, close the drawer as fast and as hard as you can. I've used this to correct alignment issue. Sometimes the drawer will need to be removed and reset and other times you might have a bad rail. Good Luck
Aug 15, 2017 | KitchenAid Refrigerators
My iphone 3g 8gb seems frozen, on my main screen it says slide to unlock, well it won't slide to unlock, ive turned it on and off again and done the reset thing but no joy at all, does this mean my...
try the new update that just came out today , sync your phone in itunes and then install the new update on the ios software . hopefully this works
May 05, 2011 | Apple Cell Phones
My IPOD 30GB is in a frozen mode. Stuck on a song but there is no sound and I cant move forward, increase sound or shut off. The battery is fully charged.
to reset an ipod you flip the hold switch on the back off then hold the middle button and play/pause button at then same time until you see the apple logo. a reset is the only thing you can do besides letting the battery drain. (this happened to me also i suspected a certain song of causing it if it happens again try to recall the song playing) also i would clear the ipods music and re-sync it
Mar 31, 2011 | Computers & Internet
Nano is frozen in a song. No sound. Won't shut down or respond to any function. Doesn't show up on computer when plugged into USB.
Have you already attempted to reset the iPod?
If not you will want to attempt that as your first step towards resolving this issue.
To do so you will need to simply press and hold both the center and menu buttons for at least ten seconds or until the apple icon appears on the screen.
If this does not resolve your issue please do let me know.
Jan 12, 2010 | Apple iPod nano
My Philips GoGear MP3 Player is stuck
Been using this for a few months. Froze up on same song while on vacation last month, and continued to play same song on repeat until battery went down. Now is frozen with "Do Not Disconnect" as it was being charged on my laptop. Attempted to unplug and plug back in and Windows gives DO NOT DISCONNECT!!!!!
I am having the exact same problem!!!!!
Aug 02, 2009 | Philips GOGEAR SA6045 MP3 Player
Creative Zen screen is frozen on ZEN
If you have tried the reset hole on the bottom, try the mp3 player recovery tool here.
Feb 12, 2009 | Creative Labs Zen Digital Media Player
Screen Is Frozen Grey.
did you try to reset it? paperclip in small reset hole on side? sorry if thats to obvious but hey it happens that people don't know..
Dec 12, 2008 | Creative Labs Zen Digital Media Player
Frozen screen
On the very bottom of your Walkman, next to where you'd normally put the USB cable on the left side (when the screen is facing you) is a reset button. Hit it with a pin, that should do it :)
Jun 03, 2008 | Sony Walkman NWZ-S616F MP3 Player
What does "synchronize to continue music subscription" mean
the best way to put music into the mp3 player is by using windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Jan 23, 2008 | SanDisk Sansa c200 MP3 Player
Zen sleek frozen after trying to delete songs
Why does technology make you work for what you already paid good money for? Have you tried going into Recovery Mode? You do this by holding down the Play/Pause button while triggering the Reset button. Once there, you have four options. Try selecting Disk Cleanup and then Reboot. You might need to re-Sync a few things but it's worth a shot. Good luck.
Dec 16, 2006 | Creative Labs ZEN SLEEK MP3 Player
iRiver Clix Digital Media Player Logo
276 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
