My wife said that the screen went to computer looking screen and now the HDMI inputs have great picture but no sound? I don't know.
  • 8,457 Answers
Reset to all original setting u should get it back or just unplug the tv over night u should get back if there is no damage to any electronics componnents.
Posted on Sep 26, 2009
I have a 42 inch panasonic plasma tv, I have great picture and sound on hdmi input only
From a quick look at the tv spec it would seem to cope with most inputs so I wonder if it may be due to input type selection. Mine on some inputs have sub options on its inputs which would be in the screen menu (mine has rca sockets and can become component or normal video input).
You say you can hear sound but no picture which sugests there is a signal of some sort (tv's and video's inputs become live when a video signal is present but if its poor in some way will not show) but allow sound through.
If the game is old then it may not conform to modern standards so present a blank screen. its hard to say what may be the problem but I think input selection or an incompatible signal looks to be a possible answer (if you have your plug ins correct)
Hope this helps.....
Jul 02, 2017 | Panasonic Viera TH-42PZ80U Plasma TV
Trouble with a Sony KDF-E50A10
sounds more like the video control board to me. You'll find that video drive is fundamental reason why these go 'black'
Mar 05, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
Settin TV to AV
Look at your remote for a button called "input options" and press that button while watching your screen to see the various choices available. Everytime you press that button, you should see a change on the screen from one choice of input method to the other. It should says things like "AUX, video 1, video 2, hdmi, AV - ect. Keep pressing that button until you see a picture of find the AV input method you want to keep and that should solve your problem.
Apr 15, 2012 | Sony Televison & Video
No picture or sound when I plugged in HDMI cables to back of PDP-R04E media receiver
Hi there
I do not know what SKY is,but if it is a kind of a transformer that is connected to the router. I have that because of the ADSL.
I discovered that this transformer has to be "new" in order to plug the HDMI cable in the transformer and the HDMI socket. I hope my English is understandable because this HDMI and scarts are a bitcomplecated to explain but simple inpractice.
all the best
Kolbrun
Feb 29, 2012 | Audio Players & Recorders
I have a toshiba tv and a sony dvd player and i want to know how to install the jacks and if i need the hdmi cord
It really all depends on what else you may have hooked up and, what inputs you have on your TV. If you have an open HDMI in on your TV, I would use that because you will get your sound and vidoe with one cable(HDMI). If you don not have an open HDMI port on your TV, component cables are the your next best option video wise. The component cables do not carry sound so, you would have to get your sound by using,(best) digital optical or RCA. After looking at your player, your best picture would be using component and, it says it has SPIDF out but doesn't exactly specify what kind but, if you don't have the component cables, use youe RCA jacks(yellow), video out, and red and white(left and right audio) out from player to suitable input on TV. If I looked at the right player, there is no HDMI out on it.
Jul 02, 2011 | Sony DVP-SR200P DVD Player
Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
Toshiba Regza 42" lost all hdmi input
TV was on, screen went black... Stanley cup playoffs double OT continued sound only. TV now just clicks on and off.
Mar 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
