Home | Sharp | R-1874 850 Watts Convection / Microwave Oven | My Sharp R-1874 over the...
Sharp R-1874 850 Watts Convection / Microwave Oven
Problem for Sharp R-1874 850 Watts Convection / Microwave Oven
My Sharp R-1874 over the range oven quit working.
By ottawayj on Sep 26, 2009
My Sharp R-1874 over the range oven quit working. Is there a fuse?
Solution #1
posted on Sep 26, 2009
Not Rated)
Tnfixit
Rank: Guru
Rating: 92%, 38 votes
Yes. Unfortunatly, the fuse is usaully located behind the keypad mounted on a circuit board. You may have to remove a few screws to remove it. hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Sharp R-1874 850 Watts
Questions and Unsolved Problems for Sharp R-1874 850 Watts
Do you recommend Sharp R-1874 850 Watts Convection / Microwave Oven?
Answer
Answer
sharp R1874 works only intermitently If you put 2 minutes it only works for 1 minute 1 sec.
Answer
Suddenly, after 3 yrs. use, turntable not operable. Driving-stud does not turn.
Answer
The panel display on my Sharp microwave R874 Jet Convection and Double Grill does not work since we... (More)
Answer
Sharp microwave R-1874. Does not heat Timer, lights, cooling fan work. Turn table does not turn ,... (More)
Answer
I wou;d ;ole tp rep;ace a sharp R-1874F with a GE advantium. Do they fit in the same space and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp R-1874 850 Watts...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
