Question about Whirlpool Dryers
RUNS BUT WON'T HEAT - Whirlpool Dryers
  • Whirlpool Master
  • 2,605 Answers
Is it gas or electric ? if it's gas, good be a ignitor, flame sensor, etc. if electric...check your breaker. is this a new home, new wiring, just moved in ? don't just visually inspect the breaker either, I mean physically turn the breaker (it should be 30amp) "off" and then back "on". breakers can partially trip, which will still supply the unit with 120v hence allowing the drum to turn, but the heater cannot come on.
NOTE; keep in mind if the breaker is tripped, have the unit inspected, it's a symptom to another problem.
good luck
Posted on Sep 26, 2009
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
Runs but won't hit up
check heater element. could just be a loose wire/connection. or element needs replacing
Jan 06, 2012 | Kenmore Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Samsung dv218eb dryer runs but won't heat
No heat almost always means a heating element. But if you ar talking low heat, then check the lint filter; exhaust pipe for clogges and that the fan is circulating the heat up to the drum.
Aug 14, 2011 | Samsung Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
My dryer runs, but does not generate any heat. Is
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | KitchenAid KEYS750LQ Electric Dryer
Runs but no heat
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Car runs fine till it is turned off
two things come to mind....
1- a electrical component may be heat sensitive and not function after turn off heat soak
2- your fuel pump check valve isn't holding fuel pressure in the fuel loop
Next time check for spark...if thers's spark it's a fuel problem
Mar 24, 2009 | 1997 Oldsmobile Achieva
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
