Question about Canon PowerShot SD1100 IS Digital Camera
Lens error, lens jammed - Canon PowerShot SD1100 IS Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
  • 502 Answers
Does the lens seem stuck, does it not extend or retract properly? Try to unjam the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Posted on Jul 15, 2010
My camera will turn on then shut off a few seconds after even if it has been charging for an hour whats wrong?
Most likely the lens is jammed or stuck. The unit is trying to initialize, and not being able to, shutting itself down. Dust and sand can work it's way into the lens assembly, and jam the gears. You can try to spray it out with compressed air to try and free it up. If that doesn't work, here's some things you can try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The page is for lens errors, but it applies to your problem.
They say about 50% of the cameras with a lens error/shutdown problem can be fixed.
Good luck, thanks for using FixYa, and hope this helps.
Aug 20, 2010 | Samsung L200 Digital Camera
Zoom error
There is a problem in the zoom functions of the lens assembly. Dust and lint can get in it and jam it, and you can try to spray compressed air into the lens in hopes of freeing it up. A gear can also be jammed, or stripped. If it's just jammed, you may be able to fix it yourself. Here is a web page that details all the things you can try to get it working. They say about half of the cameras with these problems can be fixed by trying their suggestions. The article says it's for lens errors, but it applies to the problem you're having:
If none of these tips help, the camera will have to be serviced. Get an estimate first, since the cost of repair can exceed the replacement cost of a new one. Good luck, and hope this helps.
Jun 14, 2010 | Fuji FinePix A600 Digital Camera
Im getting a lens error message on my h3dii ....message reads ... lens error id 21:1
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 22, 2010 | Hasselblad H3DII-31 Digital Camera
My Olmpus fe-360 wont turn on the lens won't retract and it beeps when I try to turn it on
The lens is jammed, which means a gear is stripped or damaged, or jammed in the lens assembly, and the electronic "brain" is turning it off, since it's not in the right position (retracted). This can be caused by the camera getting bumped while the lens was out, dust, dirt, or sand can get in the lens through the front of the camera and jam it, or the batteries could be weak. After you make sure your batteries are good, and it still isn't working, go to this web page and try their suggestions. They report about 1/2 of the cameras with a lens problem can be fixed trying their suggestions. If that doesn't work, don't have it serviced- you can buy a better new camera than what you would pay a service shop.
The page says "lens error" messages, but it also applies to your problem.
Apr 08, 2010 | Olympus FE-360 Digital Camera
I have a camera canon powershot and the lens was out of the camera while it was off. Now when i try to power on the camera the message error: "lens error. restart the camera".
you have a mechanical jam in the lens gear chain. It happens often when lens is extended, the camera may have slight impact or pressure on the lens, it damages the plastic gear chain and jams. You can try with very light force, jiggle the lens while tuning on the power to disengage from the jam. If this does not help, you need a help from repair technician. Average repair price for this repair would be around $115. -James
Apr 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Mar 28, 2009 | Nikon COOLPIX S200 Digital Camera
Lens is jammed for Canon Powershot SD200
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 05, 2009 | Canon PowerShot A470 Digital Camera
Lens error
same happened with mine. some people pushed it back in or used a thin driver to jam in in between the side with the bigger gap.
try it while you press the on button.
Mine is still jammed so I'm going to either get it replaced but try disassembling it first.
Aug 28, 2008 | Nikon Coolpix 5200 Digital Camera
Lens error
The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try:
Dec 09, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
209 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
