Question about Linksys Rangeplus Wireless Pc Adapter
Blank square on screen after installing a Linksys USB adapter
After installing a Linksys Range Plus USB adapter, I keep getting a square on the screen that is either blank, or lags information as you scroll up or down. The blank square is about 3/4"X3/4" dead center. Any idea's?
  • Linksys Master
  • 6,487 Answers
This is a problem with the wireless adapter to correct this problem you uninstall and download the latest software from linksys site and install that one to your computer...
Posted on Sep 26, 2009
Unkown device when plus in usb to pc
Hi there
As I understand it you get Unkown device notice when you plug the router in to your PC via USB.
With routers/modems/access points that have USB connection the PC do not pick up the USB like other devices. You will have to install the drivers for the USB which will be on the CD that came with the Linksys.
You can go to the following link to get more details on the drivers: Linksys(Cisco) Support
Hope this helps
Feb 03, 2011 | Linksys Wireless-G WUSB54G 802.11g/b
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Error 211
    When getting error 211, you will need to manually install the drivers for the adapter.
    Exit from the error message, then remove the CD and restart your computer.
    Plug linksys usb adapter, the computer will detect the adapter.
    Right-click on My computer then click properties, go to Hardware > Device Manager.
    Under Other Devices, you will see 802.11 g WLAN with an exclamation point. Right-click on it and select Update drivers.
    Then insert the CD. (If the installation setup screen appears, just exit it.)
    Then on the update driver screen, click browse and select your CD-ROM drive.
    Then click finish.
    If you are using Win 7, follow the steps from this link.
    If you cannot open the link, just go to kb.linksys.com. In the search bar type 20873. Answer title: Error 211 - Installing Driver Manually for network adapters to work in Win7.
    I hope this helps!
    Apr 29, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
    Have linksys router and adapter .blank paper image no icons
    Not necessary ... U can simply uninstall and install the adapter from device manager ...
    Sep 23, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
    Installation is stuck at 30%
    hi
    may be the installation software is not working,what you need to do is take the cd out from the computer and just plugg the wireless adapter,when you plug in the wireless adapter it will tell you to insert the cd that came with the usb card so that the software can be installed,once you see this message insert the cd and then follow the setup screen(imp thing:incase you see the screen of the linkys installation donot follow that,follow the windows software setup screen) this will install the software and i am sure the software will get installed if the software has totally gone bad then here is a link you can donwnload the software from website and then try the installation
    link for linksys wusb54gsc for :
    http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1154470123093&pagename=Linksys%2FCommon%2FVisitorWrapper
    vedhick
    Jan 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
    Cannot finish installing
    It means you have to plug in your computer to the router through a ethernet cord. Most computers have one, and on the back of thats router has 4 ehternet female ports. Plug it in, and run it again.
    Dec 02, 2008 | Linksys Wireless-G WRT54G Router
    Upgraded Acer 2500 Travelmate with a Wireless card
    hey there is a external linksys wireless network adapter that works well it plugs in your usb slot
    they are by linksys.
    Linksys
    Range Plus Wireless USB Compact Adapter should get you the correct range for around home and outside in your yard. check ebay for this solution its much cheaper here. thanks Kawuna
    Dec 01, 2008 | Acer TravelMate 2500 Notebook
    Win98, Linksys USB Adapter, 2wire router... no internet
    hi!
    sorry if it took a while to get an answer to your question...
    anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
    launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
    on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
    on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
    under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
    under network setting select obtain an IP address automatically (DHCP) & click on next.
    under security settings choose "disabled" for WEP and leave the rest of the fields blank.
    confirm the settings by clicking on yes.
    note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
    also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
    i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
    please let me know if you have any issues... we'll work this one out, ok?
    Apr 16, 2008 | 2wire (1000-400108-001) Router
    Connect Wireless
    The PS3 doesny need an adapter, its already wireless. You need to set up ur wireless network as normal, the connect your PS£ through the settings :)
    Mar 12, 2008 | Sony Playstation 3 (PS3) Console
    Linksys Rangeplus Wireless Pc Adapter  Logo
    75 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
