Question about RCA P52930BL 52" Rear Projection Television
Memory issues turn tv off then turn tv back on and no chanels u have to wait 15 or more min. to get any chanels and some times u have to reset tv all over again. help meeeeeeeeeeeeeeeeeeeee!!!!!!
  • 552 Answers
You may be having a problem with the a sleep timer or parental control.
Check you operators manual for some information on that.
Posted on Feb 13, 2008
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
I have an Emerson LC320EM8A tv. I am able to turn the tv on either by the remote or at the unit. After about 15 min, the tv changes changes the channel to Video1. I can change the channel back to...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 10, 2017 | Emerson LC320EM8 32 in. LCD TV
Tv won't change from chanel to chanel
Do a hard reset to this set and check first. To make it hard reset, unplug the set from AC mains wall socket, and re-plug it back after 10 minutes or so.If this do not help you, check and replace its main system memory IC.
Sep 29, 2012 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Have to tune in channels when turning tv back on
Talk to LG to see if a KNOWN issue for your model.
Jun 26, 2012 | LG 32LC2D Television
I have no signal for 48 hours my other samsung mobile is ok please help
hello there!
i can help you with your problem. just follow these easy steps:
1. turn off your mobile phone.2. remove the battery, sim card, and memory card ( if you do have ) of the mobile phone.3. wait for 15 mins.4. after 15 mins of waiting, put in back the battery, sim card and the memory card. wipe first the sim card and memory card before putting in.5. turn on your phone.
I'm pretty sure that after turning on your phone you will do have a signal.whenever you encounter this again, just do this procedure.
kindly rate this post and thank you for choosing fixya.
Jan 25, 2012 | Samsung Star GT-S5233 Cell Phone
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
I can see the cable guide and hear the chanel on my TV but there is no picture on any station - the screen is black
Cable boxes can latch up from time to time. It can be from a momentary poer loss or poor ventilation or any number of things. Try pulling the plug on your cable box for about 15 seconds, then plug it back in. Wait for it to reboot. If this does not correct the problem, contact your cable provider and ask them to send a reset signal to your box. I hope this was helpful, best wishes.
Mar 29, 2010 | LG 42LG30 42 in. LCD HDTV
I have a Hitachi 57F500 HDTV SRS TV and can not get any chanels
unplg tv 4 30 min plug bak in if does not reset u will have remove supply voltage to computer clock 2 do this u must go into back of tv and look on board until u find a whats looks like a watch battery remove it wait 6 minutes reinsert it this just reset the clok in the microprcesser dumped the ram this should fix ur problem everthimg should go back 2 factory seettings read manual
Jul 25, 2009 | Hitachi 51F500 51" Rear Projection...
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Televison & Video Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
