Question about Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens
Stopped working will not focus just makes a noise
  • 667 Answers
I have seen the focus gears fail on these. They come as a unit. It will need to be replaced, not a DIY
Posted on Dec 07, 2009
2010 ford focus automatic trsnsmission makes rubbing noise when accelerating from acomplete stop . noise continues until 2nd gear engages. from then on all is fine. reverse sometimes doesnt engage, ma
A carrier bearing usually pertains to the differential assembly and would not cause the symptom you describe. There is a problem with this transmission that causes it to not drop completely to first gear after a period of driving. Ford is aware of it but I do not believe they have initiated a recall. Call your Ford dealer(s) to see if you can find an honest man. Ask for the service manager.
Mar 25, 2014 | 2010 Ford Focus 1.6
2005 ford focus zx4 ac compresser making noise when ac is turned on
Yes, it could be the ac clutch or the compressor itself.
Jul 08, 2012 | 2005 Ford Focus
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
My ford focus zetec makes a rattleing noise
spraying WD40 on drive belts is not a good option as it can cause slippage it is better to use silicon spray or ordinary soap,rub the soap on the belt when the engine is stopped,as for the squeak it could well be the tensioner replace it first it may be the cheapest to start with.....hope this helps....cheers
Jul 26, 2010 | 2001 Ford Focus
2003 Ford Focus 78,000 miles...clacking noise
soiunds like a wrist pin but more like a cracked piston,
May 11, 2010 | 2000 Ford Focus
2005 ford focus makes load noise when heater fan is on???
Maybe a stray leaf, twig or other small object has been sucked into the ventilation duct, touching the centrifugal fan.
You need to pull off ducts around fan and inspect.
Nov 17, 2017 | 2000 Ford Focus
Focus front brake grinding noise on frist braking in the mornring
Look for a metal tab at the brake. It's only supposed to touch (and make noise) when the brakes are worn down. Sounds like it's bent in too far.
Mar 25, 2009 | 2005 Ford Focus
55-200mm VR focus noise
The lenses have a focus motor built into them.when the camera is set to auto focus, once you press the shutter button, the motor activates to set the correct focus. VR is for motion stabilization. Turn off AF on lenses and camera and see if noise stops.
Dec 12, 2017 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens Logo
172 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
