Question about Aiwa XR-M131 Shelf System
CD's sound awful
Tried several CDs and when the CD does play (which is not every time and not for long periods of time) there is a lot of background noise. Also, the player is unable to read the CD (same one I've played in my daughter's room for 5 years and I've burned a new one just in case it was the CD) every time. It just keeps searching.
  • 537 Answers
Try cleaning the lens with a CD lens cleaner. If that doesn't work, the optical pickup may be back. If tht is the case, it can be repaired but it will probably cost quite a bit (more than $100) to repair.
Posted on Dec 17, 2007
Help!! I have a library CD stuck in the CD changer. I can see it but it will not eject...it won't even acknowledge that it has a CD in the changer. I have tried tweezers, switching CD slots and trying to...
TRY TURNING OFF CD PLAYER.WAIT 10 MINUTES THEN TURN CD PLAYER BACK ON THEN PRESS THE EJECT BUTTON.SOME TIMES CDS PLAYERS GET HOT WHEN PLAYED FOR A LONG PERIOD OF TIME.MY CDS SEEMS GET STUCK WHEN I PLAY CD PLAYER LONG TIME.SOMETIMES IF CD DONT COME OUT .IF IT STICKING OUT JUST A LITTLE.TRY PUSHING BACK IN CD PLAYER THEN EJECT IT.THIS TRICK WORKS SOME TIMES.
Mar 11, 2011 | 2002 Ford Escape
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
My dell studio laptop (one month old) has problems playing dvds
It sounds like you have eliminated a media player problem.
Here are some more things you could try:
Disable your antivirus when playing the movie.
Have Dell replace CD/DVD drive. I got a bad drive in my new Latitude and they replaced it. It was a long phone call...be prepared.
It could be overheating. Make sure you have good air flow under the notebook. They make notebook coolers which you can find with a web search.
If this helps please vote for my solution.
Jan 19, 2010 | Dell Studio 15 Laptop
Unsupported format message for normal CDs
Have you tried completely powering down the system, removing the power cord from the wall socket? If not, please try that. Wait two minutes. Then plug it in and power up the system. If this does not clear the problem, contact Bose, to get the latest firmware disk. The firmware disk will reprogram your Lifestyle sound system. Then, everything should work properly.
Jan 17, 2010 | Bose Lifestyle 48 System
CAN I PROGAM MY JUKEBOX TO PLAY FOR 8HRS EVERY DAY ?
Yes. You need to set the time correctly then set the background music to play for 8 hours starting at a specific time. The background music only uses the top 20 CDs of the 120.
Dec 04, 2009 | Wurlitzer Jukebox Princess 120-Disc CD...
JVC KD-S580 will not read CDs
i have worked with stereos alot in my life and i can tell you that its exactly what your gut feeling is. if your good with electronics try to find a used one off craigslist or something and replace the cd drive, as that would be number one thought in my mind.
Jul 10, 2009 | JVC KD-S580 CD Player
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
May 21, 2008 | Clarion DXZ438R CD Player
PDM-0822BD
This is called "audio transfer saturation. Rarely happens but will when there is constant use of player. Drain saturation by removing battery (if attached), With the power adapter still attached, turn off player and unplug adapter from wall for several hours. Saturation should discharge back through you adapter. Disconnect adapter from player before plugging back into wall.You may have to do this periodically when constant music is played.
Feb 29, 2008 | Polaroid PDM-0824 Portable DVD Player
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Feb 07, 2008 | Aiwa CDC-Z127 CD Player
Aiwa XR-M131 Shelf System Logo
65 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
