Question about Jandy Laars Lt 400,000 Btu Heater
My Jandy LT 400k heater shuts off when the fan transitions back to high speed about 30 seconds after burners light. The gas pressure is about 13.8 and the regulator is at 9 inches at the manifold side of the valve when the burners are lit. I have jumped around the high limit, 135 and 150 limit, water pressure switch, fusable link and air pressure switch. Something is shutting off the gas valve about the same time the fan gos back on high or the fan is blowing out the burners and the flame sensor is shutting it down. I remove the fan and there are no blockages I can see... what next? I am not sure where to go from here. Any suggestions
  • michael_ludw Oct 01, 2009
    Flame sensor at control unit measured 7.7 micro-amps. Adjusted damper to close off air opening below the burners (about 50%) and the flame no longer goes out. So the problem was it was running too rich and by increasing draft via burners damper the issue is resolved.
  • michael_ludw Oct 15, 2009
    joespools200,
    No I am not a pool guy, but did run service for HVAC back in the 80s and understand the basics but it doesn't need answering as I finally figured it out.
Heater comes on for about 2 minutes then service light comes on and so does the ags light
Posted on Jan 27, 2010
    Champion:
  • 246 Answers
My guess is you are a pool guy so im not going to awser this one
Posted on Oct 15, 2009
Heater burners ignite but than shuts off after a few minutes
check gas pressure if ok then check hi limits and make sure heater isn't overheating or sounds like too small gas line
Aug 04, 2013 | Jandy Laars Lt 250,000 Btu Heater
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
The heater won't light up on my Jandy LXi400n Lxi heater
make sure red light is on for calling for heat if so make sure 24 volts ac on both sides of pressure switch if ok make sure gas is on
Jul 13, 2012 | Jandy LXI400N Lxi Pool & Spa Heater -...
On the jandy 400 lt its displaying the AGS code... what does that mean?
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
My ecosense 180dvn sends out an error code of 13 after 2min 30 seconds. It is always after 2:30 min. I can shut it off after 2 min and back on and it continues to run. But the water has to be shut off...
I have the exact same problem with error code 13 on my Rheem/Ecosense 180dvn . The unit ran good for at least a year, and then I started getting the same error 13 every few minutes. I called the Rheem service department, and they told me to check the vent installation as well as the gas pressure. I reinstalled the vent with new seals. I only have about 6 ft of vent, so there should be very little resistance. I checked the gas pressure, and it shows 9 in H20 pressure, which is well in the range recommended. The service center scoffed at the suggestion that it could be their circuit board. I am totally at a losss and at the verge of ripping this very expensive installation out of my attic.
Jan 30, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Have a Goodman GMT070-3B which the vent motor seems to be sticking. I took apart and cleaned the brushes and reassembled. The furnace will come on only after what seems like the vent motor comes up to...
The whole assembly must be replaced.
The sequence of operation is -
Combustion fan purges the heat exchanger. A pressure switch verifies combustion air fan is running. Usually a 30-45 second purge before the hot surface ignitor glows, or the spark ignition starts.
Gas valve opens after 10-15 seconds and main burners light. Control board monitors for flame and shuts gas valve after 2-3 seconds if main burner does not light.
If burner does not light, some boards repeat this for 3 tries, then locks out and is reset by cycling power.
Air blower comes on after another 30-45 seconds after main burner ignition.
Times may vary based on the specific controller board. A flow chart and timing sequence should be located somewhere on the unit, usually in the fan compartment.
Dec 16, 2009 | Goodman GMS90703BXA Heater
Jandy Laars Lt 400,000 Btu Heater Logo
418 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
