Question about RCA F32650 32" TV
RCA 32v430t When I go to turn my tv on it makes a clicking sound like it's going to go on it flashes on the tv screen like the picture is going to go on then it clicks off and it keeps doing this over and over, on and off. The green light on the button stays on during the whole time. Any suggestions.
  • fermin Dec 19, 2007
    1. i have a Toshiba 52' that was doing the same thing and the replacement lamp eventually went out so that may be the problem. part cost around 200 dollars.
  • turbo5150 Dec 20, 2007
    I have the exact same problem. can anyone help.I cant even find a repair place in my area
    Genius:
  • 1,694 Answers
Peanut36,
Bad HV transformer = RCA part # 271996.......................T.
fermin,
Please log on to Toshiba rear projection Television>>>>>>>>>
turbo5150,
The exact same problem with ? = Make & Model,please....T.
Posted on Dec 24, 2007
I have an RCA 32V430T, when i turn it on, it stays for about 5 sec then the picture goes out but the sound is still on, the pic covers only 3/4 of the screen and has lines across it, i was told i prob...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 06, 2017 | RCA 32V430T 32" TV
RCA light comes on and then goes off. Tv doesn't turn on
replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
http://servicemanuals.vstore.ca/
May 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv has sound picture is dark more like a night schene
A lot of diagnosis can be made from a picture of the screen if you have a digital camera.
If you want to send a photo of the screen (no flash), post your email address back here (use AT instead of @ since this doesn't attract the 'spiders' that spammers use).  I will respond so you can send me the photo as an attachment.   This could be as simple as an internal adjustment that has drifted or the control on the 'flyback' transformer become intermittant.
It can also be caused by certain capacitors that have failed.
I would recommend you have the set repaired and stored if you buy a new flat panel set since these are not lasting as long as you RCA likely has. If you don't have a digital to analog converter box yet, get the government coupon and by the converter to store with the set. You may need it again after the flat panel set dies and all services have converted to digital transmissions. Your set will not be able to recieve them without the box.
Apr 06, 2009 | RCA 32V430T 32" TV
RCA MODEL #32V434T
Mine does the same thing I'm thinking a fuse has blown out and if taken to a tv repair shop or finding the right size fuse you can fix or get it fixed yourself..
Apr 10, 2008 | RCA 32V430T 32" TV
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Nov 23, 2007 | RCA 32V430T 32" TV
No sound, no picture. TV clicks on and off over and over.
You both have bad Flyback Transfomers.this is not a fix it at home problem .ThankYou for using FixYa. Have a Nice Day.
Oct 04, 2007 | RCA 32V430T 32" TV
Have you ever had this problem?
Generally,pincushion may be driven by a chip or IC,but pin out is normally a durable xistor. Servicer adjustments are minor for pin correction.Go to pin out circuit & measure voltages.Get back to me on your findings.
Nov 04, 2006 | RCA 32V430T 32" TV
RCA F32650 32" TV Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
