Question about Goodman CLQ36AR49 Air Conditioner
Fan is spinning on compressor but air inside not cooling house
Fan is spinning on compressor but it buzzes and dosent kick the cold air into house
    Problem Solver:
  • 19 Answers
That means that it can be the capasitor for the compressor is faulty or it can be one of the windings in the compressor is burnt
Posted on Sep 26, 2009
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Amana Prestige II air conditioner. The fan unit on the top of the ouside unit stopped spinning. I gave the fan a good push and it started spinning (and continues to spin) however the air now blowing into...
You need to replace the fan capacitor. Your compressor is probably in thermal overload you can cure this by turning off the disconnect your ac voltage and taking a cool water hose and running over the top of the compressor for a while. Then turn your disconnect back on and listen and feel of the big copper line to see if it gets cold and also listen to see if the compressor kicks on.
Aug 08, 2011 | Heating & Cooling
My Samsung RS2630SH fridge and freezer are not staying cold. The condenser fan is running, I blew and vacuumed all dust off of the coils. If I unplug it for a few minutes then plug it back in the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
Hey, I have a goodman cple30-1 that won't "kick on" it just lightly buzzes when the fan should start moving The inside fan works fine just no cold air.. thanks Im trying to save the $150 house call
What exactly is buzzing? is the compressor running without the fan? It may be the contactor buzzing and if nothing is running this may indicate that the breaker is tripped as the control voltage may be coming from the indoor unit. Let me know what you find out
seth
Jul 18, 2009 | Goodman CKL42AR42 Air Conditioner
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Buzzing and then no cold air
You need a service tech to check out your system. Your compressor may not be starting which could be the reason for the humming noise and no cold air. Dead snake may not be related to your problem.
May 14, 2008 | Weather King 10AJA2501AH Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
196 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
