Question about Stoves Ovens
Decals for temperatures on stove worn off... any suggestions as to where I can get the decals?
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: Number and temperature decals washed off my stove
you can find your model number behind the drawer
sometimes it is on the back side of the drawer front
hope this helps
but to asssure you both have repalceable mylar covers
Posted on Nov 02, 2009
Oven temperatures now unreadable - worn out. Any suggestions? Thanks
appliance repair shops or online search for replacement transfer decals or replacement panel
Jun 04, 2018 | Smeg Ovens
I have an old Admiral stove, unknown model #. Black, smooth top- all else is white. Wording on the oven buttons have erased, i have no clue what degree i am setting to and or if baking/broiling. Help!
go on line and type in admiral stoves
there are pages of parts suppliers
on the back of the stove or inside the inspection plate at the back there will be a decal stating the model and serial number of the stove
Apr 23, 2015 | Ovens
GE Monogram oven ZET1SMSS decals rubbed off. I called GE parts and they said they do not just sell the "overlay." They said I would have to purchase the control panel (~$400) to fix the problem. REALL
I had a very similar problem with my oven so I contacted www.ovenlettering.co.uk who supplied me with excellent quality replacement decals with super fast delivery!
The video on the website made it easy to apply them too
Feb 01, 2013 | GE Ovens
Ge stove f2
Likely the problem is a bad oven temperature sensor and/or the oven sensor plug.
I suggest inspect the wire harness (remove back cover); additionally, could try to eliminate the plugs and connect the wires using a high temperature porcelain wire nuts.
Hope this helps (remember to rating this answrr and leave some testimonial comments).
Oct 08, 2011 | Ovens
I have a Kenmore oven model # 665.95024100 and used the logi-clean cycle and now the door will not open. This happened before when I used it and I called the repair service to fix it but I cannot remember...
Articles on the internet suggest not using the self cleaning feature of modern ovens, becuase fuses and other parts may easily burn out due to the high temperature.
Suggested methods to open a locked Kenmore oven at the artlcle at the link below:
http://homeguides.sfgate.com/clear-oven-lock-mechanism-kenmore-stove-71754.html
How to Clear the Oven Lock Mechanism on Kenmore Stove
Feb 26, 2018 | Kenmore 40494 / 40495 / 40499 Electric...
Oven is cutting out after leaving it does come on again. Do they have cut off switches,
Hi ebttw,
Yes they do, these cutouts are situated on the inside attached to the outer cavity of the stove.
If the outer cavity gets too hot, it cuts out power to the element (sometimes the whole stove) to prevent any damages. If the temperature then goes down, it then allows continuity to go through it again.
I'd suggest checking your temperatures with a digital thermometer (Can be purchased almost anywhere), it could be the start of a faulty Thermostat.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 03, 2011 | Stoves Premier 900DCa Dual Double Oven
Can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
Apr 10, 2010 | Stoves 720EF Electric Double Oven
Number and temperature decals washed off my stove. I can't even remember right now if its a hotpoint or a frigidaire~ that washed away too!
hope this helps
Nov 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Diplomat ADP3322/3340 oven, temperature markings rubbed off
You can buy the decals from Ovenlettering.co.uk they send you a sketch of the control panel so you know where to place each number.
Aug 29, 2009 | Ovens
Ovens Logo
93 people viewed this question
Top Stoves Ovens Experts
ashburton
John Tripp
John Tripp
Are you a Stoves Oven Expert? Answer questions, earn points and help others
