Question about Maytag 24 in. MDBH965AW Built-in Dishwasher
Maytag dishwasher MDBH965AWW touchpad lights are malfunctioning
No matter which button is pressed, the touchpad will show the insta-wash option. The cycle will sometimes work when start is pressed, but just as often will do nothing when it is touched. When the cycle actually functions, the numerals on the display are only partially visible.
jsrock516
  • 5911 Answers
SOURCE: maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Posted on Jul 31, 2007
SOURCE: maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Posted on Sep 11, 2007
  • 1003 Answers
SOURCE: Maytag MDBH950AWS Dishwasher won't start
REPLACE TIMER
Posted on Jan 18, 2008
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
SOURCE: We have a Maytag MDBH950AWS Dishwasher that won't start.
I have Miele incognito that when I shut the door it does not turn on? Not sure why it stopped working all the sudden
Posted on Dec 23, 2008
Have a Whirlpool dishwasher model GU1200xtks. It is at least 8 years old. The dishwasher is malfunctioning. Sometimes the panel lights does not turn on but it sounds like the motor turns on automatically...
Bad touchpad user interface, is sticking in cancel mode causing unit to drain continuously... Replace both user interface and main control board due to software corruption
Jan 31, 2015 | Whirlpool Dishwashers
Maytag dishwasher will not start
REPLACE THE DOOR SWITCH.....NOT GETTING RUN COMMAND CAUSE SWITCH N DOOR NOT BEING MADE
Oct 15, 2013 | Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
My maytag quiet series 200 wont do anything when I press the start button. there are no lights. I have tried tripping the circuits?
Mine would not start, and could not set any options. I read online to try resetting by pressing Heated Wash, then Heated Dry, then repeat both. I did it and my machine cleared and worked fine. Give it a try!
Dec 13, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Some of the buttons on the touchpad will not work. What can we do? Normal wash and Insta wash and Auto wash will not light up, nor does the time display for these two options go on. Heated Dry and Sanitize...
Unfortunately the only way to fix that problem is to replace the console which includes the button pad. I can look up the part number and approx cost of the part if you confirm your model number from the tag just inside the door and the color of the dishwasher.
Apr 25, 2010 | Maytag 24 in. MDB8751A Jetclean II...
Our dishwasher's lock indicator won't turn off, even after holding down the heated dry button for 3 seconds. We also tried disconnecting the power for 5 minutes and it would not reset. What part do I...
Try holding the button down for longer say 5 seconds. When you push the button and hold it the little green light should blink. I would disconnect the power for longer..try 20 minutes. If that does not work then remove the inner panel and disconnect the control panel connector from the control box then plug it back in...see if that clears the locked control. If it continues to have a problem then you may need to replace the control panel.
Sep 27, 2009 | Maytag Dishwashers
Dishwasher does not drain...stops in cycle...no matter what cycle
HI, this is a control fault. the logic chips are malfunctioning. these chips are responsible for initiating the proper washing cycle sequences. you will need to replace this damaged control board asap.
Click here to order your new control board online.
Jun 04, 2009 | Maytag MDBH955AWS Stainless Steel 24 in....
No power to dishwasher
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Nov 28, 2008 | Dishwashers
Maytag dishwasher mdbh950awb
Jul 31, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Maytag 24 in. MDBH965AW Built-in Dishwasher Logo
488 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
