Question about JVC KW-AVX810 Car DVD Player
My bottom buttons dont work i cant turn it down or take cd out but none of the buttons work maybe some ribbon cable rip i dk but i need to fix it
    President:
  • JVC Master
  • 1,114 Answers
If the unit has "soft touch" buttons, like a little "click" when you push it. check them all to make sure one is not jammed. It's not too uncommon for that to happen. Or the buttons have worn out. They will average 3-5 years on a good deck with normal use. If it's still not functional, I would send it out for service. Most car audio repairs cost between 100-125 to fix. Trying to find parts yourself then actually doing the repair is like pulling teeth or performing heart surgery on yourself if your not an experienced tech. Hope this helps
Posted on Sep 26, 2009
My radio is not responding.
Put the right bottom corner of the face to head unit,bring the left bottom corner to headunit and press gently.
Apr 08, 2009 | Pioneer DEH-P6800MP CD Player
Camera turns on but it does nothing.
The ribbon cable for the buttons has either come out of its socket because it was not locked down (does happen) or it is broken and will need to be replaced. Fuji will not send out spare parts but will fix it for a price. Last quote I got from fuji to fix the keypad ribbon on an F470 was £80. check ebay for donor camera
Jan 24, 2009 | Fuji FinePix V10 Digital Camera
Black out
this is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Jan 21, 2009 | Sony CDX-M800 CD Player
Sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Aug 30, 2008 | Sony CDX-M610 CD Player
Top popped off.
I just removed the cover from my wave radio. There are 3 screws that hold the top cover on. Two are exposed and in the rear of the unit and the other is under the CD player lid.
To replace the cover find the two tabs in the front on the bottom cover. Slide the top on and using a screwdriver carefully pry back the front of the top cover so that the two tabs slip by and move into place. Then open up the CD player cover and make sure the spindle fits through the hole in the top cover. Push down and replace the screws.
I didnt remove the ribbon cable so you will have to check on how to refit the connector.
Apr 07, 2008 | Bose Wave Radio
AVIC-N1 opens to blanks screen and none of buttons work
It is probably the ribbon cable that you can see when the screen closes. This is a known problem and the part is sometimes hard to find. But is available.
Mar 26, 2008 | Pioneer AVIC-N1 Car DVD Player
No video on Ibm Thinkpad T23
hi
i also have a t23, and i have messed around with the display a lot...
there are several things to consider:
1) your operating system. i would assume you are using windows xp, and that you dont get video even before the OS starts up in the first place, but its just something to consider: i have heard of some video bugs with the t23 under linux
2) you should check to see if the laptop display and the video out problems are related in the first place. to be honest, i dont know why they would or would not be related. the display not work because a) its just plain broken (although in this case there are usually some somewhat obvious cracks) b) the ribbon cable from the display to the motherboard could have ripped (they do so very easily). if the ribbon cable is ripped in its usual place, you MIGHT just not have a backlight. make sure that there is nothing on the screen, not just a normal display extremely dark. if theres definitely no picture, then you have to take the laptop most of the way apart, but you can start with just the screen casing. its fairly easy to figure out how to take apart, but you might want to look it up. behind the screen casing you can see the ribbon cable and whether or not its ripped. oh, but before you do that, try turning the led light on thats built into the top of the screen. its also part of the ribbon cable. you can do this by pressing the fn key and page down or something next to the brightness buttons. if that doesnt work then your ribbon cable is either ripped, or of course it could just be a motherboard problem in which case all of what ive said is fairly useless information. if you want you can also take off the keyboard and top casing from the screws in the bottom and look at where the ribbon cable (and maybe the video out too) meets the motherboard, just in case theres an obvious problem or disconnect. it probably wont be very obvious. however, if you do discover fairly surely that it is the ribbon cable, then you can get them for very cheap. search "ibm thinkpad lcd video cable t23"
hope i could be of some help
Mar 17, 2008 | IBM ThinkPad T23 2647 Notebook
Nintendo DS bottom display screen
Hi I have a problem with my bottom screen as well. I was replacing the case as the hinge was broken. When i was putting it back together i noticed a slight tear in the ribbon cable which is attached to the board and the bottom screen.
When I turned it on I found I had poor colour and contrast in the bottom screen however the top screen was fine.
Where this ribbon cable is attached to the board there is two small cables attached to the board beneath it, maybe one of these has come away and needs repositioning or your bottom screen needs replacing.Try this site for diy tipshttp://site.powergamingparts.com
Cheers Chris
Oct 24, 2007 | Nintendo DS Console
File errors? hard drive failure? I dont know..
Sounds like a possible hard drive failure. Have you tried to do a reset? Toggle the hold button on and then off. Then hold down the menu button and the center button at the same time. hold them until the screen flashes. then release. You may have to try this several times.
Jun 06, 2007 | Apple iPod 4th Generation MP3 Player
Cd player
I would first check for a broken or disconnected wire or cable. then check all of the fuses. After this the unit will need to come out of the car and be bench checked. Good Luck
Apr 03, 2007 | Pioneer DEH-P44 CD Player
JVC KW-AVX810 Car DVD Player Logo
239 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
