Question about Electrolux Dryers
My electrolux IQ touch front load gas dryer goes to pause immediately after pushing the start button
4 Suggested Answers
SOURCE: My new Electrolux IQ 8.0 cuft dryer smells like
From http://tedmalone.blogspot.com/2009/06/dryer-problem-solved.html
It turns out that the inlet vent in most dryers is louvered to mix in some outside air with the air being heated by the gas (~ 500 degrees F). In an effort to be more efficient, Electrolux removed these louvers and have not been able to lower the heat enough in their gas dryers to keep from burning clothes. Furthermore, it turns out there is a *new part* which if you're in-the-know you can order. It is the same part, but with the louvers back.
Posted on Apr 20, 2010
heatman101
  • 43501 Answers
SOURCE: I have an Electrolux IQ
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Testimonial: "Thanks for the advice. Yesterday a technician came, said the same thing, took the cover off, spun the cylinder and it worked. Must have been blocked"
Jahn27
  • 1554 Answers
SOURCE: Hi! Have a Electrolux front load dryer Model
There are only two possibilities why this happens. First is a faulty control board and second is a fault in the heating circuit and there's one simple way to determine which is which; that is disabling the heating element by disconnecting the safety thermostat.
Start by unplugging the dryer then remove the two screws securing the to panel to the rear of the dryer as shown and lift the panel off.
Once the top panel is removed, locate the safety thermostat on the heater housing at the rear of the drum with black and red wires. Refer to the illustration for the location of the safety thermostat.
Disconnect the wires from the safety thermostat terminals and properly insulate the connectors with an electrical tape. Do not tape them together.
Once the wires are insulated, plug the dryer back in and run it in heat setting mode. Check the heating element coils for any part touching the housing if the dryer does not shut off. Otherwise, replace the electronic control board which is part number 34523200.
Posted on Sep 13, 2010
My electrolux dryer was working fine and now it won't start
The hum normally comes from the motor trying to start turning but wont.....motor problem.
Jan 21, 2016 | Electrolux EIMED60LT Front Load Electric...
Nothing happens when the 'Start Button' is pressed on Electrolux Front load washer
Good Morning friend, thank you for your post!
From my understanding your Electrolux washer is not starting no matter what buttons are pushed. This could be a possible problem with your keypad or control panel. I noticed that you have already performed a reset and that was done when you unplugged your washer for 15 minutes. I would now recommend having a technician out to perform a diagnosis. In order to do so you would need to disassemble your washer and test each component to make sure they are working properly. The technician would have the appropriate tools needed to do this accurately. If you need some assistance locating a technician you should be able to visit the manufacturer's website for additional assistance. I hope this information is helpful for you. -Matt
May 20, 2015 | Electrolux IQ-Touch Series EIFLS60LT 27"...
Eifls60jiw washer goes right to pause
You probably have a stuck button on the touch pad. Try pressing it repeatedly firmly it may unstick.Otherwise you may need to call a pro to diagnose the problem.
Nov 17, 2013 | Electrolux EIFLS60JIW Front Load Washer...
What caN I POSSIBLY DO NEXT? 6 KIDS NO WASHER, AND SERVICE WARRANTY SUCKS!
Problem closing the door
Door lock faulty
Wiring faulty
Main board faulty
Cycle is paused Start
Apr 28, 2012 | Electrolux EIFLW55HMB Front-Load Washer...
I have an Electrolux IQ Touch dryer. Just now it stopped working. When I hit the start button, it makes a buzzing sound and then goes on Pause. I called Electrolux and they had no idea what was...
heatman101
Aug 25, 2010 | Electrolux Dryers
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Dryers Logo
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
