Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PWO
Control Locked is on. I can't get it off to do laundry. HELP!
  • entremanure Dec 17, 2007
    I left the door open after completing a load on "Normal." The "control locked" light is on and I tried using cancel, change the dial, holding control and pause at the same time, etc. I have also unplugged the machine for over 30 seconds with no solution.
    I have the same problem as Railtrekker's.
  • Mark Lewandowski May 11, 2010
    Whirlpool duet model WFW9400SU00 giving F70 or F71 code?
  • 537 Answers
You must press in the control lock for a few seconds to disengage it I believe. Try unplugging and replugging the the unit if that doesn't work.
Posted on Dec 17, 2007
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
The 'Control Locked light' is on and the washing machine will not do anything. I even unplugged and replugged the unit. It will not operate. It is model #GHW9150PWO BOUGHT IN 2005. Thank...
I had that problem before go to the front of the washer and go over to the End of cycle signal and hold the button for 3 seconds that should unlock it I hope this helps
Jul 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model# GHW9150PWO the contol locked light stays on and nothing else will work.
Hi
To unlock control press the END OF CYCLE SIGNAL button for 10 seconds. Hope this helps...
Dan
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model # GHW9150PWO The control locked light stays on the other bottons will not work
Hi
Dan
Code f 71
Check to see whether the laundry drum to the washer moves. If it does move, then the user interface needs replacing. If the drum is locked and will not move, you need to replace the central control unit on the washer.
Read more: Whirlpool Duet Error Code F71 ' eHow.com http://www.ehow.com/facts_7618431_whirlpool-duet-error-code-f71.html#ixzz1AANUprMm
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor
Control Unit (MCU) cannot be sent correctly.
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer model GHW9150PWO show the that the controls are locked. There is nothing that functions when this is going on all other buttons are inoperative.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((*(*))))
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool ghw9150pwo
Press & hold the button on right of panel 'end of cycle' for 3 seconds, the light will go off. Child lock. <It will come on again if you dont vote me nice!!>
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
448 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
