Question about Philips FW-D5 CD Shelf System
Nothing happens when plugged into wall.....no lights no hint of any life at all .it worked one day then it didnt........has it a fuse?.....if so where is it
    Scholar:
  • 43 Answers
Fuse may be in the back of the cabinet. If the cabinet is removable, and you probably will find screws under a label or two, if you take all you can see out, and the cabinet still won't come apart, feel across any labels and see if you find a hole, which will contain a "hidden" screw, but, probably the fuse will be near the entrance to the power cord. Make sure you unplug the appliance FIRST and then remove the case screws and look for a glass fuse in a holder somewhere near or around the power cord area. If you have a multimeter, you can check to see if power is indeed coming to the system where the power cord is connected to the lugs, if so, you could possibly have a defective power switch. A little investigation (CAREFUL INVESTIGATION) will more than likely result in your finding the fuse, and or the problem.
Posted on Sep 26, 2009
Tv has no life in it at all wont switch on no lights nothing only 2 yrs old tried changing fuse, unplugging from wall but still nothing help me plzzzz
if you have no life and you changed the fuse the you have a dead power supply,.that is the board you replaced the fuse,.is there a red light showing, or flashing, if not then you do have power problem,.did you see and capastors popped,.
Jan 19, 2012 | LG 42LC2D 42 in. LCD HDTV
When I turn the piano on, nothing happens I checked the plug-in but still nothing happened. I just played the piano a couple of days ago and it was fine. Do they have fuses which need to be...
I woulld not even venture a guess as to what brand/model/ etc you have. How do you expect us to have any idea to help you?
I will say that a very common problem is if the unit, whatever type it is, has a power adapter, it is COMMON for the plug to work loose... If your unit has a regular cord, then there are likely fuse(s) inside, but if they blow, there is another problem that must be repaired before fuses are replaced.
Does the unit have any lights or displays that show power is on? If nothing is lit, then VERIFY that the cord is plugged in at both ends... ANOTHER problem is that SOME wall receptacles are switched... intended for floor lamps and if one has the switch off the receptacles is dead...
Again, you haven't given us enough info to really help you...
Nov 10, 2010 | Music
Iphone 3gs died today. Just went off, no restrat seems to work. plugged into computer and tried restart and still nothing, plugged into wall socket and still nothing - literally dead to the world. Computer...
That happened to me once but i did a forced restart
Have you guys tried a forced restart?? if not try it, its very simple.
press and hold both your home and sleep mode buttons togeather until the phone starts.. let me know if it works.
Nov 06, 2010 | Apple iPhone Smartphone
Power cord plugged in no lights on power brick
ring xbox tell em u didnt do anything to it and its just broken they sent me a free new one :) so they should u it was with me after 2-3 days
so get a new free one and end any future problems
Sep 01, 2009 | Microsoft Xbox 360 Console
Power Light on constantly ....no pic or sound....nothing.
Yep, your mainboard is damaged.
Replace it and your tv will work again
Jun 02, 2009 | Westinghouse SK-32H240S Television
Turn signals dont work 97 Geo Metro
we found the flasher curcuit had no power to the hot prong. So my friend wired the flashers hot prong into the radios fuse curcuit to get power to it and put a separate 10amp fuse on the new lead.
Jan 22, 2009 | 1991 Geo Metro
Jvc rx-dv31 standby light comes on, but wont turn on, just clicks then turns off
sorry but this is an electronic malfuction or failure , it will need repair
leave it unplugged to prevent further dammage untill you can take it to your local electronic repair shop
electech
Oct 27, 2008 | JVC RX-DV31 DVD Player
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Philips FW-D5 CD Shelf System Logo
191 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
