Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
The refrige temp takes a long time to get cold when u open it
Make sure the door is closed all the way, and there is plenty of space around the fridge
Posted on Sep 26, 2009
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Kenmore Refrig Model 596.50699000, not getting cold as should. Frost forming on top row of coils only?????
Clean the condenser. Probably below refrig. Reset all settings to mid point and check to see if you have a restricted drain tube.
Jun 17, 2012 | Kenmore Side by Side Refrigerator
Meat and vegetables placed in the produce drawers turn to ice. fridge temp set at 39. freezer set at 0. as you face the fridge, the drawer on your left is the worst. fruit is okay in right drawer.
check the damper door vent assembly located between the freezer and refrige compartments and make sure its not frozen open so as to let cold air in all the time,adjust the temp in the refrige and the door should open and close with adjustments,if not then damper door motor assy or the electronic control board is defective that supplies power to this door
May 13, 2010 | GE PDS22MCR Bottom Freezer Refrigerator
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator cold control doesn't work; temperature stays at or below freezing. Freezer control OK.
check the damper door between the refrige and freezer compartments,its behind a plastic cover,if its iced up in the fully open condition it will allow too much cold air into the refrige,if this is the case defrost it with a hair dryer and recheck operation,otherwise the temp control in the refrige is bad
Mar 18, 2010 | Refrigerators
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
The fridge gets very cold even when I turned down the temp to #1
You have air dampers in this fridge.
Adjust them to a warmer setting.
Look along the left wall down low beside the vegetable bins.
If this does not correct the problem you have electronic temp sensors that have gone bad.
A technician will be needed to determine that.
Keep your fingers crossed that the damper is too open.
Any adjustment will take 24 hours to be noticeable.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
43 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
