Question about Vacuums
How can I switch to a reverse setting on my vacuum?
    President:
  • 389 Answers
Almost certainly you can't. Every vacuum I've ever seen is made to run one way only. If you think you've got one that should be able to run in reverse, please post your question again, giving details of make and model.
Posted on Sep 26, 2009
How do i replace the on off switch on Hoover U6485900
Make sure the power cord is disconnected! There are two sets of three screws one needs to remove. The first set hold the handle assembly to the sweeper body (there are two near the back of assembly and one in front). The second set is inside the cavity that hold the vacuum powered cleaning tool. There are two at the bottom of the cavity and one at the top. Refer to the Assembly Instructions in the Owner's Manual for help. One can then remove the power leads from the on/off switch, push the switch out, and insert a replacement switch. Pay attention to the color of the wires because some switches apparently work with models having 2 black wires (H-28161075), others with a black and yellow wire (H-28161074), and others with connectors to the wires. Reassemble the sweeper reversing the dis-assembly process outlined above.
Jan 02, 2014 | Hoover U6485900 Bagged Upright Vacuum
Tip
How To Replace the On / Off Switch On Hoover Windtunnel Self-Propelled Uprights
What you'll need to do this repair:
- Phillips head screwdriver
- Needle Nose Pliers
- Hoover Windtunnel Switch For All Upright Models
Step 1. Turn the vacuum cleaner around so that the back is facing you. Remove the two screws at the top of the vacuum that are holding the handle on the machine. Please see the picture below of the two highlighted screws that need to be removed;
Step 2. After these two screws have been removed, simply slide the handle backwards, and remove it completely from the vacuum and set it aside. You now can see the on/off switch, but you can't easily change it from here, you'll need to complete several other steps before you can remove the switch. Here's what the vacuum should look like after removing the handle:
Step 3. After removing the handle from the vacuum, turn the machine around so the front of it is facing you. Open the vacuum bag door and set the door aside. Also remove any attachments that are on-board in the tool storage bin, this model has a hand-held turbo brush stored here. After removing both of these parts, you'll need to unscrew 3 screws that holds the tool caddy onto the vacuum cleaner. I have circled the area where these 3 screws are located:
Step 4. After removing these three screws, pull the tool caddy off of the vacuum by pulling straight forward by using the tool caddy lid. You'll now have access to both the front and the back sides of the switch. Use your needle nose pliers to remove the two wires that are attached to the switch. Be careful when pulling these wires off because if you pull too hard, then it will break the switch terminal off inside of the wire. Most models have the wire that has a plastic covering over the end of it on the top, and the metal terminal is connected on the bottom. The two lead wires that need to be removed are highlighted:
Step 5. After the wires have been removed from the switch, turn the vacuum back around so that the back of the machine is facing you. Simply use your flat head screwdriver to pry the switch off. You may push on the back side of the switch where the wires connect to it in order to give a space so that you can get a screw driver behind it. Here's how it should look:
Step 6. Once the old switch has been removed, simply push the new switch into the open hole. Important: Make sure that the Off setting of the switch is at the bottom, and the part of the switch that says on is on the top, otherwise the switch will be reversed. Re-attach the wires to the switch, with the wire that has the plastic covering on top, and the metal wire terminal on the bottom. The only tricky part of reassembling is when you put the handle assembly back on the vacuum. As you can see, there is a metal cable below the switch. This metal cable controls the self-propelled mechanism. If you look at the handle assembly, you'll see where the self propelled cable sits inside. The easiest way to line these up is to pull the cable up to the top, and then line up the rod inside of the handle that the cable goes in, and slide the handle back on the vacuum.
I hope this was helpful.
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover U6476-900 WindTunnel Vacuum
Tip
How To Replace the On / Off Switch on Hoover Windtunnel Self-Propelled Uprights
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover U6434-900 Bagged Upright Vacuum
Is there a switch that reverses from sucking air in to blowing air out
No there are NOT switch Normally this motor from AC, doesnot have this device for reverse. Only you can do it by open the motor and chaging the connections
Now you must shure the a) hose is clogged b) bag is clogged c) or there another thing maybe a sock. please use the common sense
However you can go to the web page from kenmore and see your instr. manual download:
http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu
Jul 27, 2012 | Kenmore 31913 Progressive Direct Drive...
I recently purchased a house with a Filter Queen Central cleaning system model FQ-7500. My problem is that instead of sucking air it blows the air out. How do I reverse the air flow?
Never seen this model but it is on of two things,the hose is hooked up wrong or the motor is either switched in reverse or the motor has been reversed with wire leads
Feb 17, 2011 | Filter Queen Majestic Canister Vacuum
My kirby g4 motor runs backwards and so the power drive when pushed forward wants to go backwards. I need the wiring diagram so I can get it wired correctly.
The wires to the switch, coming from the carbon brushes, have been reversed. The carbon brush closest to the switch goes on the lower switch terminal.
Dec 24, 2010 | Kirby Generation 3 Bagged Upright Vacuum
How do I change the power cord on my Filter Queen vacuum cleaner?
First, remove the top filter cap. quarter turn.
Remove the three screws from under said cap.
The rubber switch cover will come off of the on/off switch pedal there. pull off and set aside.
undo the two clamps and remove the motor (chrome) section from the base.
give the handle a tug and the chrome cap should now come off and allow you access to the wiring and motor/switch.
optional side note: at this point you may want to replace the sponge filter around the motor too.
Remove the cord from the unit and rewire to the same spots the old cord comes out of.
reverse the instructions to put the machine back together.
Nov 05, 2010 | Filter Queen Majestic Canister Vacuum
Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
E drive problem. Self propelled feature drives in reverse, but not in forward.
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
Feb 27, 2007 | Dirt Devil M087700SV Bagless Upright...
Vacuums Logo
95 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
