Question about Samsung Digimax D53 Digital Camera
My samsung Digimax D53 beeps 3 times when i try turning it on
I try turning it on and the green light turns on, and then beeps 3 times... i've tried new bateries and i tried a different sd card and it still does the beeping...
  • 7 more comments
  • TBICK Dec 27, 2007
    i tried lithium... and it still doesnt work
  • ONHOLD Jan 02, 2008
    Having the same problem with the D53. Green light turns on and beeps 3 times. Batteries cant be the problem with mine. Have tried rechargeable and regular batteries, still the same 3 beeps and nothing more. Have let the camera set for possible reset and still nothing.
  • dapmmm Jan 08, 2008
    3 beeps and turns off. tried several brand new sets of batteries.
  • cameradude93 Jan 09, 2008
    I need this camera to be working very badly. There is no way to get this working? I've used my original nickel metal hydride batteries, and it still makes the 3 beeps and stays off. Plus, my lens is stuck open. I need help with this ASAP.
  • Anonymous Jan 13, 2008
    my samsung Digimax D53 beeps 3 times when i try turning it on ....i tried new batterries and it still wont turn on
    my samsung Digimax D53 beeps 3 times when i try turning it on....i put new batterys and it still wont turn on...can somebody help me?
    my samsung Digimax D53 beeps 3 times when i try turning it on....i put new batterys and it still wont turn on. can somebody please help me?
  • Anonymous Feb 21, 2008
    I dropped my camera, with lens out...then got the same 3 beeps and shut down. I looked over the lens carefully, as it was stuck OUT...I noticed the bottom was slightly off-kilter on the outer most lens...so I pulled on it (gently) until the bottom popped out...now all works fine!!
  • KoolDebi Aug 11, 2008
    I had the same three beeps as all of the other post and camera wouldnt turn on. I tried gently pulling on the lens while turning the camera on, because it wouldnt come out before and would beep 3 times and shut off. (it was as if the lens was stuck and couldnt come out) By gently adjusting and helping the lens come out while turning the camera on , it fixed the problem and the camera works great again.
Mine does the same thing!!!
People we should sue the company1
Posted on Feb 06, 2008
Mine is not exactly a solution...I just wanted to share my experience with this very same problem over the past 3 days. Nothing worked, new batteries...newly charged batteries. So I brought the camera to work this morning, hoping my boss would be able to help me solve this problem. And all of a sudden it worked on its own ater I tried turning it on for about the 75th time. Has anyone figured out why the camera is doing this?
Posted on Jan 28, 2008
I had this problem as well and now i use energizer rechargeables and it works great...
Posted on Jan 19, 2008
  • 4 Answers
I had the same problem with my samsung d53. I used energizer rechargable nimh batteries with 2500 mah and they worked!
Posted on Jan 15, 2008
  • 3 Answers
Use lithium bettery
Posted on Dec 26, 2007
I HAVE A DIGIMAX D53 AND WHEN I TURN IT ON THE MONITOR HAS A DULL LIGHT BUT FADES AND BEEPS 3 TIMES. i DO NOT GET A A MENU OR PICTURE WHEN I HAVE A MEMORY CARD INSERTED.
Does it turn off immediately after the it beeped? Are you using a rechargeable battery? Have you tried fully charging the it? You should also try fresh set of batteries and see if it will resolve your problem.
Oct 20, 2011 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 will not stay on
This is most likely a lens failure. Try contacting your manufacture if your camera is still under warranty. If not, try contacting your local electronic repair shop to get it fixed. Hope this helps!
Dec 07, 2009 | Samsung Digimax D53 Digital Camera
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
3 beeps
had the same problem with my D53 eneded up buyin a new camera pulled the D53 out the other day was going to toss it then i noticed the lense was just a lil crooked i played with it a freed it up camera works great now
Sep 23, 2008 | Samsung Digimax D53 Digital Camera
D53 camera will not fully turn on...help??
If you've tried the suggestions for similar problems on here - use NiMH or lithium batteries (not alkalines), then it may be a warantee job. Afraid I don't have any other suggestions.
Sep 05, 2008 | Samsung Digimax D53 Digital Camera
Camera not turning on
my camera just wont turn on period and just used it like half an hour ago
May 31, 2008 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 beeps and shuts off
I had the exact same problem. Camera turned on but turned off soon after, with lens still outside. I noticed the lens was crooked as if it was stuck. I pulled it out and I heard it click into place, for a second I thought I had broken it. I then turned it on and everything was working again ! Whew ! Problem Solved :D Good luck!!
Mar 15, 2008 | Samsung Digimax D53 Digital Camera
Problem with startup
my samsung d53 issue is .when u turn it on it beeps 3 times and shuts off. thats all it does.... cant take a picture its like the batteries are low.But they are not. what is wrong. like new! jimmy
Jan 27, 2008 | Samsung Digimax D53 Digital Camera
Camera won't turn on
use a lithium or nimh battery and it should work. regular alkaline is not good in this camera
Dec 13, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 camera
lenses are jammed. send it to a service technician. sorry.
Oct 03, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Digital Camera Logo
272 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
