Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Refrigerator only gets down to between 40 and 42 degrees...coils are clean and setting is on full cold
  • EVE23 Nov 02, 2009
    My refrigerator doesn't cool on the top shelf and it freezes my vegetables in the vegetable drawer. We also get frost in the freezer and ice cubes freeze into one big ice block. Please help!
  • Mike Smith
    Mike Smith May 11, 2010
    The temp for the refrig should be 0 degrees for freezer , and 38-42 degrees for the refrig . You could have dirty coils under the front of the fridge . Remove the bottom toe plate , and vacuum the coils . Only need to vacuum what you can see . Doesn't sound like a too serious of a problem , however , if you see frost beginning to form on the inside rear freezer wall , then a defrost problem could be developing . If so , reply back with that information , and an expert will be able to help with the defrost problem .
    Problem Solver:
  • 5 Answers
Capillary stopped up
Posted on Sep 26, 2009
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The regrig doesn't get cold enough52 degree @ max setting
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 16, 2011 | Sunbeam Refrigerators
It is not holding temp. its range is 30 to 49 degrees in one hour
As a refrigerator, it should not go below about 34 degrees. If it is going down to 30, it may be freezing up on the coil. If you get a chance, do this: unplug the refrigerator and let it sit for 4 hours with the door open. If the coil is frozen it will defrost. You can feel the coils inside the box at the top back inside the unit. If you feel ice at any time it is an indication that it is getting too cold. Once the inside coils freeze over, the air can't flow through the coils and the unit will get warmer and warmer. When it is defrosted, set the thermostat just above the off setting. Let it run until the compressor shuts off. See what the temperature reads on a thermometer inside the cooler. If it is not cool enough move the thermostat one number colder and let it run an hour. Take your time, let it equalize before you change the thermostat. Also if the cooler is empty it is hard to set the thermostat because when you open the door all the cold air escapes and the temp will change rapidly. If it is full of cold food, opening the door won't change the temperature very quickly. Also check the radiator coils at the bottom of the cooler behind the grill. If it is clogged with dust or grease, the compressor may overheat and shut off prematurely.
Sep 21, 2010 | True T-49 Side by Side Refrigerator...
Refrigerator section will not keep a constant temperature
Check the coils at the back of the freezer for ice build up. If there is have it defrosted by unplugging the unit and have it cleaned. If there are none, have the coils cleaned with something soft. Otherwise there could be a problem with the thermostat.
Aug 24, 2009 | KitchenAid KSSC42QKS Side by Side...
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
473 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
