Question about Canon iRC3100 Printer
Setup my canon irc3100 to scan to pc
How can i setup my canon irc3100 to scan to an email address or PC
  • 2 more comments
  • susan405 Sep 26, 2009
    Hi
    I don't have a manual and need step by step help.
    It is all new to me.
    I had an IT company come yesterday and setup the printer on the network but they didn't know how to setup the scanning.
    So it is all on the network but not sure how to scan to get the docs on the PC.
    Susan
    I require a step by step instructions.
    the printer is all connetced to the network but no ides how to get it to scan to the pc or email.
    This manual does not help me at all? Are you able to tell me how to setup the printer?
  • susan405 Sep 27, 2009
    Hi again
    If you could email me at susan@kinnaghcivil.com there is no send option on my machine.
  • 662 Answers
Click below to download the user manual and you have the instructions on page 12
CANON irc3100 Usermanual
This information may also be helpful to you.
When SMTP authentication is used, all the IR i series infact(IR 2200i, IR 3300i, IR 2220i, IR 3320i, etc, ) will not be able to scan to e-mail as the mail server will only allow mail with authentication to be send . The work around is to install a mail server on a PC to relay the mail (if it is possible for you to install that in customer location). You can try using postcast smtp mail server(PostCast Server - Free SMTP Server) but the pc you install the mail server on need to be able to access the internet.
If mail server(SMTP) is external (if all setting like DNS, Gateway, Domain and email address is set correctly) there will be no issue send e-mail to external and internal e-mail. As for internal mail server(SMTP) you would also be able to send e-mail to both internal and external e-mail unless the mail server have policy to block external e-mail.( If this happen you need to ask the mail server administrator to configure the mail server to allow the IR to relay mail.)
POP Setting is only for IR to recieve I-Fax.
Posted on Sep 27, 2009
  • Laxman Bisht
    Laxman Bisht Sep 27, 2009
    It is not necessary to create a e-mail address for the copier.
    You can use a dummy e-mail, but I prefer to use a valid e-mail address
    in case of reverse DNS in some mail server. You may used any valid
    e-mail or you may also create a e-mail address for the copier.
  • Laxman Bisht
    YOU WILL SEE THE SEND BUTTON ON THE SOFTWARE NOT ON THE MACHINE
  • 615 Answers
Scanning & Sending Colour Documents - Once connected to your network, the iR 3100C is an intelligent device. Which means you can send black and white and color documents to many destinations in a single operation. Once scanned in, they can be distributed to wherever they are needed – individual e-mail addresses, a specific database or to a file server for storage. After you connect to the net select scan and the unit will take yhou step by step.
Do you need step by step instructions of how to do it or you have the manual? Let me know what exactly you need and I will work with you .
Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Posted on Sep 26, 2009
  • 3 more comments
  • Norman Al-Anbar Sep 26, 2009
    Susan,
    I will try to post a step by step instruction for you to use...
    Susan,
    I thought as you do not have any documentation for the printer I may give you as much as I can to help you for this issue and others...go to the following link and download the document and see how much information contains that help you and what is missing so I can work on it more...let me know. Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
    http://ithelp.lincoln.ac.nz/site/story_i...
    Before sending email, you need to create the documentation’s first by one of the two following methods: Job Build or Mailboxes, as the space is limited I will address only the Mailboxes:
    Mailbox
    Set up your Mailbox under Additional Functions - Mailbox Settings - Give the Mailbox a name - and make sure the deletion time on the Mailbox is set to “0”. You are also able to give your Mailbox a pin number (up to 7 digits).
    Select the Mailbox screen, and select the Mailbox you want to store the document into
    Select Scan
    Name your document If you don’t do this it will get a time and date name -which will make it more difficult to find your job at a later date.
    Select the features you want to use - especially any quality options as this is the way the document is stored. Although you are able to change the way a document prints you will not be able to change any of the quality options.
    Put the documents in the feeder and press Start - if you are using Job Build keep adding pages until you have scanned the whole document
    When this is completed press Done. The document is stored into the Mailbox
    After you done creating the documentations to be sent or printed select one of the followings:
    To Send an Email
    Select the Send Tab screen
    Select the Address Book and select the address required and press OK
    (If you do not have the Email address preset in the Address Book you can manually enter it from the Qwerty Keyboard.)
    Choose the file type TIFF or PDF
    If your original is Two Sided press the Two Sided Original Key.
    Select the layout of your original (most are book type).
    Press OK
    Choose the resolution that is required from 200dpi to 600dpi.
    Press the Green Start button.
    Again thank you for giving me this opportunity to assist you and hope that the above-mentioned steps meet your approval.Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
    Susan,
    I thought that you need to scan from the printer and e-mail the materials, if you need to scan from the printer to the workstations that is ok…do you have on the system a utility program called Canon’s Color Network ScanGear that is the one that you use to pull scanned images from the imageRUNNER C3100 Series over a network to a destination PC or file server...let me know
    Susan,
    If this is what you are looking for then I can provide you this step by step to use the computer to scan a document to your PC and then e-mail it or print, etc. this is a long document and they will not allow us to use more than the limited space available and that is not much…Do you have n e-mail address that I can send you the step by step instructions as well as copy of the user guide?
    Again thank you for giving me this opportunity to assist you Please see that grant me your approvals by rating my service and I hope that I can serve you again the future
I have a second hand Canon IRC3100. The computer is networked to this copier, however, it will not print and has a message "Scanning has stopped because the memory is full" Can anyone help
Navigate through the menus, in order to "delete previous scan images" (that are stored on a disk-drive inside the printer). Very sloppy of the previous owner of the printer to _NOT_ "delete" all those scanned items, before selling the printer. Post all those scans to Wiki Leaks. :-)
Jan 24, 2011 | Canon iRC3100 Printer
How can i hook up the scanner?
Hook the network cable to your scanner nec card on the machines, note that this machine has two nec cards, one for printer and one for scanner.
after that Go to the setting and under setting/Scanner Default create and ip address for the scanner. after you done from that go to the computer browser, type in the ip address, you can choose scan to smb or pc.
Scan to smb needs shard folder but scan to pc needs to run software on your computer on your pc.
Setup the sender list which you need to fill only the ip address of the machine as sender.
Go to destination setup the ip address of the computer you scanning to, the path is the shared folder name, and the user name and password of your computer and you good to go.
To make it easy for you, Provide me your email and i will attach the scanning manual to help you setup it correctly and you can always get back to me in any question.
Best Regards
Kyocer/copystar Expert
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jul 13, 2010 | Kyocera Copystar 221 Black and White...
HOW DO I SCAN AND PICK IT IN THE PC VIA NETWORK
have to share printer folder in control panel ,,,,, then got he pc from which u work ,,,, and search for printers.. choose through network ,,,,, and it will find the one on the network pc... choose it ,,,, and give him teh place for the driver..... browse for it ,,,,, then custom completetion of the proceesss and restart ,, it will work
May 27, 2010 | Canon iRC3100 Printer
Wanting to connect pc to a Canon ImageRunner C3100. Anyone have any ideas on doing this?
hi first u have to vearfy that yours irc3100 have a network card if yes then you have to
1.download latest driver for irc3100 from canon ofical website.
2. you shud have a network cross cable to connect directly from your pc if you dont want conect directly you want to conect throug yours local network in that condation you can use normal network cable,
3. you have set IP address on yours irc3100.
4. just connect networ cable and install driver on pc.
thats it enjoy
thanks
May 13, 2010 | Canon imageRUNNER C3200 Copier
I need to know whether the below canon's can scan and what the range of the DPI is that they can scan at; IRC3100 IR3320i IRC2570 Cheers
iR C3100 600 dpi if equipped with network print/scan kit.
iR3320i 200 dpi, 300 dpi, 400 dpi, 600dpi yes, can scan
iR C2570 600dpi yes, can scan
Nov 06, 2009 | Canon PC-920 Black and White Copier
Scanning and send to email
  1. Setup your mailserver IP address in the smtp server addres and asign a mail address in the same domain.
  2. Make sure sure your copier is register with a send kit that your obtain from the dealer.
Jul 01, 2009 | Canon ImageRunner 2220I Copier
Able to copy and print, scan & print, but not able to scan to pc
is your printer setup to scan to pc.need to setup email address etc.
Jun 30, 2009 | Office Equipment & Supplies
Canon IR C3100N Scanner Setup
Hi Its fair simple, if you are scanning to windows PC, Create a folder called scans in your C:\ drive. Share it and give all the permissions. Thereafter log on to your copier using the IP address in your internet explorer. Go to address, click address book one, click the second tab on your left saying register new address. thereafter enter you name, then change from FTP to SMB and then host name will be your computer name\ip address, followed by scans(\\computername\scans)just like that. followed by your username and password.
Thanks
Mar 12, 2009 | Canon imageRunner C3100 Copier
Setup scan to pc function
Find the scanner on the network... you can use a tool like Advanced IP Scanner to search the subnet and then just hunt down the IP that belongs to the device -- it may not have a name registered.  Visit each potential IP via browser (http://192.168.1.50), one will show you the Kyocera web page.  The device has two, one for printer, one for scanner.. each one on its own IP....
That's how far I've got with mine - i was hoping it supports SMB scanning, but it may not.  So now I am looking for the rest of the setup.
Dec 08, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Laserclass 730i scanner driver software
The scanning is based on scanning to email. It isn't really controlled from the computer like a typical scanner is. The settings are all on the panel of the device. They are resolution, Contrast, and Doc Type. From there, you have to configure the machine t send the scanned image to an email address. The email address requires that you have the device setup for email with a network address, smtp server, etc.
May 01, 2008 | Canon 730i Laser Printer
Canon iRC3100 Printer Logo
1,048 people viewed this question
old marine
old marine
