Question about Toshiba Satellite M115-S1061 Notebook
How do i get touchpad on toshiba laptop to work?
  • Toshiba Master
  • 7,993 Answers
Control panel (classic View). Click the mouse icon. Under TAB TouchPad ON/OFF make sure TouchPad is set to Enable.
Under advanced tab, click Advanced features setting you will find additional configurations for the touchpad.
Hope it helps.
Posted on Sep 26, 2009
  • k24674 Nov 22, 2009
    Use the key combination Fn-F9 to activate or to deactivate the TouchPad.
2 Suggested Answers
  • 2567 Answers
SOURCE: my toshiba touchpad is not working
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is enabled. If it is not, then change the setting to enabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
Posted on Nov 02, 2009
Touchpad doesnt work
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
May 03, 2013 | Toshiba Satellite A135-S4477 Notebook
How to enable touchpad on Toshiba Satellite L850?
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Oct 27, 2012 | Toshiba Satellite L850-BT2N22 Customizable...
Toshiba laptop touchpad not working
Most likely your problem is that the touchpad was disabled. Enabling/disabling could be done in two ways:
1. press Fn and F9
2. in control panel, mouse, you will find the option regarding enabling/disabling touchpad (in some machines called internal pointing device)
Aug 07, 2011 | Toshiba Satellite L655-S5101 Laptop
I accidentally deleted the installer of my toshiba satellite m35x - s109 touchpad...now the touchpad is no longer working and the 2 buttons below it...please help
hi flyrech,
You can just your touchpad needs a driver for it to work fine again. Here's the link:
http://www.driversforfree.com/omn_ofm_omd/toshiba/satellite/m35x-s109/drivers.aspx
Just download and install the "Toshiba Alps touchpad driver".
Hope this helps, inform me this is solution effective or not. Thanks.
May 12, 2011 | Toshiba Satellite M35X-S109 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
Toshiba laptop touchpad not working properly
Boot Toshiba disk to your CD ram. If you are using Toshiba Satellite 2410 it will only work with CD marked with its own model or any model of it. Open CD drive and look for Toshiba touchpad driver and install this to your PC notebook.
Jun 21, 2009 | Acer Aspire 5610-4648 Notebook
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
Touch pad refuses to work
Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba TouchPad Not Working
tap on the touchpad or click on the top rightand if that does not work it is defently the hardware or software
Jun 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Satellite M115-S1061 Notebook Logo
439 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
