Vizio lcd has sound but no picture. If i let it sit turned on for 1/2 hour the picture comes back and stays on fine. Is this an inverter board issue or something else?
  • 8,457 Answers
Yes,the backlight video inverter board is dying.must be replace,keep using the in this situation it will damage other boards later,more head aches.
Posted on Sep 26, 2009
When I turn on my vizio tv it does not have a picture but has sound. sometimes I can turn it off then back on and I will show a picture, or if I let it warm up for about a hour. what could the problem be?
Easy fix! Shop Jimmy may have the inverter board you need. If you know someone with electronics experience show them this info. Before you purchase the inverter board, have someone pull the back cover off and locate the board. I would check the center screw, and try to tighten this a little bit. I have seen this TV not have a good ground on the inverter board and will not light up. If this does not work, order the inverter board. Please check part numbers to be correct. Thanks for asking me.
Oct 03, 2013 | Vizio L32 32 in. LCD HDTV
I have a Vizio VF550XVT1A. First problem was a flickering screen that ended with the TV turning off. I replaced both invertor boards and the TV seemed to work fine for a few weeks. Now the TV works fine...
Good day sir Alfred!!!!
If your screen turns to back after a minutes but the sounds is normal..That problem is very common to all flat panel specially to LCD TV..
OK,I need to know first if your TV having a back-light when the picture went out after a minutes.If that so the possible problem is T-CON board (this board is the responsible to produce a video on all LCD TV)..
If you don't have back-light the problem is inverter board again..But before you order or install new inverter board try to find why the inverter board gone only on few weeks after you install it..the possible problem why the inverter board faulty for the short period of time is higher/lower input voltages (24vdc) comes from power supply..try to check it using volt meter or multimeter tester..it should be read 24vdc on meter..let me know if the voltage drop or higher to 24..
If the 24vdc is fine the only problem is the condition of inverter board maybe its used or partially faulty when you buy it..
if you have more queries and clarification regarding my solution please feel free to reply on this tread...
Hope it helps..
Thanks for using fixya..
Feb 18, 2012 | Vizio Televison & Video
I have a 32" LCD
Tries tv turn off and turn on again about an hour later,see if the tv do resetting,tv might be back working to normal again.If still have the same problems.The tv have 1 or 2 long boards that call LCD inverter boards.These 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the LCD screen panel to produced a pictures.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter board for the replacement.
May 13, 2011 | Televison & Video
Tv would seem to lose connection ... the screen picture would go"in and out" and then dark, and then come back on. Now the TV won't "turn on" even though the power indicator light is on.
Now,tv turn on have flashes picture few sec.dies and stiill have sound?Yes,than 1 or 2 a long LCD inverter boards are dead. Those 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.No picture or sound at all?The Tuner board is dead,that the board,where the incomming broscasting signal cable plug into it dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards or the Tunner board for the replacement.
Sep 19, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
Hi, we purchased our Vizio about 3 years ago and had trouble right from the start however we cannot locate the receipt. The problem is when we turn the TV on it runs for about 4 to 5 minutes then we loose...
Yes,this problems is the 1 or 2 long LCD inverter boards are dead.Replaced these 1 or 2 long LCD inverter boards,will solved this problems.These long LCD inverter boards help the LCD screen have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Sep 08, 2010 | Vizio VW32L 32 in. LCD HDTV
Sound is clear but no picture
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter for the replacement.It a long board in shape.
May 04, 2010 | Vizio L32 32 in. LCD HDTV
Vizio vx32 hdtv no picture or control unplug to turn off
Ur LCD Inverter board is dead.Replaced this board u will get the picture back.It a long board.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board.
Feb 17, 2010 | Vizio L32 32 in. LCD HDTV
Why is it that my vizio picture not staying on?
Ur LCD inverter board is dead.Must replaced.It usually a long board.
Jan 08, 2010 | Vizio VA26L 26 in. LCD HDTV
Tv would not come on..sound then came on.. 1 hr later picture
That sounds like a faulty inverter board.
The inverter board is the high voltage board that supplies power to the back light lamps.
The inverter must be tested and eventually replaced.
Mar 09, 2009 | Astar LTV-3201 32 in. LCD Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
Electro Med Services...
