Question about Karcher 2500 PSI Pressure Washer
Karcher 2400 Psi Pressure Washer No gain of pressure
There is no pressure coming for the nozzel. Thought it was the handle so i repalced the handle, but there is still no pressure. Any suggestions will help.....Thanks
    Brigadier General:
  • 4,090 Answers
Remove the hose from the machine. Check that water is flowing. and there is no corrosion reducing the opening. If that is OK then it is the internal seals and pressure vallve on the pressure unit Cost to have it fixed by Karcher is $200
Thanks for using FIXYA
Posted on Sep 26, 2009
Hy does water squirt out around the nozzel
Inside the nozzel, where the tip locks in, there is a groove for an o-ring. If that o-ring is missing, water will leak around the tip as you describe. Sometimes when the tip isn't fully seated in the nozzel and you pull the trigger, the tip goes flying out. The o-ring will fly out also. Most people find the tip but never see the o-ring. The o-ring is usually carried by any company or store that carries pressure washers.
Jan 20, 2013 | Garden
Installing carbs
Does it come from the fuel bowl area? Maybe it is just a vent tube for the fuel bowl. Snowmobiles have this kind of setup, just thought maybe its the same.
Jan 30, 2012 | Motorcycles
Can't get water to come threw nozzel
Sounds like you may have some calcium buildup in the hose, gun or unloader. Take the unloader (where the hoses hookup) apart and clean away the deposits. This should solve your problem.
Apr 21, 2010 | Honda Maxus Pressure Washer MX5222
Winshild pump works but the winshield fluid comes out slowly thru the nozzles
try cleaning them out with a piece of wire, the twist ties you get with freezer bags seem to work well for me, just skin down the paper from them. as well if you disconnect the hose from the nozzels and see if the pressure is there without the nozzel. if not much pressure u will need a new pump
Jan 26, 2010 | 2002 Mercury Sable
Hi my power washer dont reach high presher
hi this could just be the nozzel in the end of the lance make sure you get the right nozzel for your pump.
Jan 13, 2010 | Karcher 2500 PSI Pressure Washer
How do i open the roller area to my kenmore canister vacuum
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Power washer loses pressure. Engine runs fine. Taking the nozzel off, squeezing the trigger, and then putting the nozzel back on sometimes remedies the problem. How do I fix it? Thank you.
Your bypass valve is jamming. All you do is take it out, put a smear of o ring grease around the o rings then put back in, make sure you push it all the way in and should fix the problem.
Sep 29, 2009 | Karcher 2500 PSI Pressure Washer
When I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
532 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
