Question about Vizio VW32L 32 in. LCD HDTV
When I turn on the tv, I get the Direct tv signal
When I turn on the tv, I get the DirectTV signal and channel description on the screen, but there is no sound, and there is no show. All I see is the channel guide from Direct TV. This just started happening, and I'm not sure if it's a problem with my Direct TV converter box or the TV. Any ideas?
  • 396 Answers
Big red
go to the menu setup satelite go to check signal strengh if it reads les than 95 % check all your connections might be a loose wire
Posted on Oct 24, 2009
  • Vizio Master
  • 8,457 Answers
It ur Direct tv converter box,unplug and replug or turn power switch off/on again so the box can reboot get a new and updated informations.It well back in the air if not must call the direct tv customer service for the disk check,it not ur tv.
Posted on Sep 26, 2009
Will not record 2 channels at same time
use the troubleshooting Direct TV, from your TV section and follow the steps.go
http://www.directv.com/DTVAPP/content/support/troubleshooting
God bless you
Jul 27, 2013 | Tivo DirectTV Remote Remote Control
My RCA L32HD41TV will not work with HDMI cable. What's the problem?
If the set is used on a specific channel on the set--no signal means either a tuner or hookup problem.
If Direct tv has rear audio video outputs connect it that way.
Not clear here how or where you are connected with the box.
Apr 15, 2012 | RCA L32HD41 LCD TV
I own a Norcent TV model LT-1931. I am a DirectTV
Out of range = the tv receives a signal with a resolution higher than it can display. Connect your DirectTV to another tv and make sure that the signal is one supported by your tv (any SD format will do). If it is then connect your tv to a pc and test the supported resolutions - if none work or the image is bad then the storm has fried its image processor - a repairman should take a look at it.
Jul 29, 2010 | Norcent Technologies2703 27" TV
No Signal
Reboot ur DirectTv box.By unplug,replug it and hour later to let the box upgrade it solfware.Go to ur tv menu setup rescan it again for all the channels.It should work now.
Mar 14, 2010 | Vizio VO47L 47 in. LCD TV
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
I have direct tv hooked into my ant/cable hookup I get no channel
pull the card out of the front of the directtv box ...wait 1 minute and put back in...turn box on...hope this helps
Jan 03, 2010 | Televison & Video
Is this tv capable of receiving digital signal from directTV
The direct tv reciever has a coax output that will send a signal to channel 3 or 4 that any older telivision can recieve...so the answer is yes. You obvously need a direct tv reciever to watch direct tv on any telivision.
Nov 26, 2009 | RCA E13319 13" TV
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
Cannot use the direct tv remote to control the volume, on / off, etc.
I have directTv and an olevia TV, and DirectTV remotes do not support Olevia
Jul 25, 2008 | Televison & Video
Vizio VW32L 32 in. LCD HDTV Logo
130 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
