Question about Maytag MBF2258H Bottom Freezer Refrigerator
How do I install the control board kit Maytag Fridge MBF2258HES
  • 725 Answers
1) unplug fridge2) remove light cover.. 3) pry down control cover( pull hard you will not break it) 4) unplug control mult plug 5 unplug controls connections 6) remove boards from cover 7) install new boards 8) reinstall connection and reinstall cover and light cover
9)program control (instruction should come with new control)
Let me know if you need more help... thanks
Posted on Sep 26, 2009
Maytag frig model no mfi2569vem2 control panel not lit up and not coolong or freezing. light inside is on but dont here the motor running. we did have a power outage when issue occured
Sounds like the power outage took out your high voltage control board. This control board is located on the back of the fridge. Roll the fridge out of its position so you can get behind it. Once you have pulled out the fridge you will need to UNPLUG it. There will be a couple 1/4" screws securing the metal cover to the back left side of the fridge (if you are facing the back of it). Remove these screws to find another plastic cover which will need to be removed. This control board controls the fans and the compressor. You can take the control board out and look for a burn mark or a blown soldered fuse. According to your model number the control board part number is W10310240.
Nov 02, 2016 | Maytag Refrigerators
Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Feb 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
How can I reprogram my maytag fridge ?model number mf12269vem10
Did you change a control board and need to reprogram the controls because you installed a different control board or are you talking about changing the settings?
Jan 22, 2016 | Maytag Refrigerators
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
The entire fountain assembly needs to be replaced. The circuit boards are fried. Can this be replaced? Maytag Model MSD2756AEW The bracket holding it in place also should be replaced. Currently water is...
Part number 12001760 fountain kit(includes solenoid, flapper door &hinge pin $50,part number 61003425 control board $95,part number 61003407 fountain bracket $25.
 Depends on how much you like the fridge but thats a lot to spend on an ice dispenser. and thats assuming you do it yourself otherwise add at least another $100
Sep 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Neptune washer model #MAH4000AWW, Press start botton starts filling then shuts off after a few seconds. Move to spin it begins draining then shuts off after a few seconds
Check out your motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
These kits are offered on the www.neptunewaxmotor.com order form and they ship UPS Ground.
This kit takes about an hour to install.
Don't forget to see the info on the website regarding the defective door latch wax motor that will eventually fail and damage your machine control board.
Jul 14, 2008 | Washing Machines
Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Apr 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Maytag MBF2258H Bottom Freezer Refrigerator Logo
161 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
