Question about Facebook Social Network
Cannot connect to any applications what do i
Cannot connect to any applications what do i do?
    Brigadier General:
  • 4,090 Answers
Contact FB support
Posted on Sep 26, 2009
My Samsung Galaxy core prime won't connect to internet gives error code
What is the Error Code?
Usual causes of Internet Disconnection:
1. System is Cluttered by junk files, cache files and other unnecessary files.
2. More client-applications installed that needs server connection
3. Block by your own firewall application
Resolution:
1. Clear History Files, Cache Files, Cookies and Junk Files. You can use CCleaner Application or Advanced SystemCare Application for Mobile to clear History Files, Cache Files, Cookies and Junk Files and even optimize your mobile performance.
2. Temporarily remove client-applications installed that needs server connection.
3. Disable your own Firewall Application temporarily
4. Refresh Network connection by Disabling and Enabling it.
5. If you are connected to a Router, restart your Router if not, reset it.
These might help you.
Thanks.
NAD818
Jun 14, 2015 | Samsung Cell Phones
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
My storm 9500 can't download any software I have tried several times keep on denying.
Add, update, or delete applications on your device
You can add, update, or delete applications on your BlackBerry® device using the Applications screen in the BlackBerry® Desktop Software.
When you connect your device to your computer, your device is scanned and the applications are listed in the Applications pane.
1. Connect your device to your computer.
2. In the BlackBerry Desktop Software, click Applications.
3. When your device applications are listed, do any of the following:
• To update an application, click the + icon beside the name of the application.
• To delete an application, click the x icon beside the name of the application.
• To install an application file (.alx) that is saved on your computer, click Import files to browse to it.
4. In the Application Summary pane, review your changes.
5. Click Apply.
Dec 03, 2010 | 123Renamer Quick Flash Player
My blackberry is just sayingblockerase6 Reset
The Block Erase 6 Reset error may result from corrupt data on your BlackBerry device.
To resolve this problem, you need to complete the steps:
Reload the BlackBerry Device Software by following these steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Connect the BlackBerry device to the computer.
  3. Open BlackBerry Desktop Manager.
  4. Complete one of the following:
    1. If the Application Updates Available window appears, click Update Now. The Application Loader wizard appears.
    2. If the Application Updates Available window does not appear, double-click Application Loader. The Application Loader wizard appears.
  5. Click Next.
  6. If prompted, enter your BlackBerry device password and click Next.
    When the Application Loader wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation.
  7. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  8. Click Next.
  9. If the On the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry device.
  10. Click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Inspite of this if you find the same error, you need to follow the steps:
  1. Remove the battery from the BlackBerry device.
  2. If a media card is inserted in the BlackBerry device, remove it.
  3. Connect the BlackBerry device to your computer using the USB cable.
  4. Open BlackBerry Desktop Manager and click Option > Connection Settings.
  5. In the Connection Settings window, click Detect. Make sure the BlackBerry device is detected.
  6. Close the Connection Settings window.
  7. In BlackBerry Desktop Manager, double-click Application Loader.
  8. In the Application Loader wizard, click Next to start the loading process. The Device Application Selection screen appears displaying the applications available to load onto your BlackBerry device.
  9. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  10. Click Next. The Completing the Application Loader Wizard appears listing the applications to be installed and removed from the BlackBerry device.
  11. Click Advanced.
  12. Select the Erase all application data check box, and then click Next.
  13. Select the check box beside Do not automatically backup the application data during the loading process. This check box is selected because the data on the BlackBerry device may be corrupt.
  14. Reinsert the battery into the BlackBerry device.
  15. On the Application Loader wizard, click Next to proceed with the loading process.
  16. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  17. Reinsert the media card if one was removed earlier.
  18. Close the Application Loader wizard.
Nov 16, 2009 | RIM BlackBerry 7290
Phone erases text messages and call log
This happens because of large applications are installed on the BlackBerry smartphone.
To resolve this issue, complete the following steps:-
  1. Make sure that the BlackBerry Device Software is installed on the computer to display the correct total application space.
  2. Determine the application space that is available on the BlackBerry smartphone by completing the following steps.
a) Connect the BlackBerry smartphone to the computer.
b) Open the BlackBerry Desktop Manager.
c) Double-click Application Loader.
d) At the Device Application Selection screen, under the application selection window, note the total application space.
NOTE:-Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes.
3) Remove applications that are not required. For example, remove additional language packs and themes.
Nov 07, 2009 | RIM BlackBerry Pearl 8100
When I try to open any link in windows mail I get an error message that application cannot be found
Check for your internet connection/network connection to the application where the link redirects you. Probably being on a different domain or without proper connectivity the authentication is not taking place hence it prompts for access denied or no application connectivity
May 17, 2009 | HP Computers & Internet
I have a blackberry pearl 8100 and it turned off and now all it will do is flash a red light in the upper right hand corner. I have taken out the battery memory card messed with the sims card. What...
This behavior indicates that no applications are installed on the BlackBerry smartphone
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION
  1. Verify that BlackBerry Device Software is installed on the computer.
  2. If the BlackBerry smartphone is connected to a laptop computer using a docking station, disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
  4. If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
  5. In the BlackBerry Desktop Manager, double-click Application Loader.
  6. Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Apr 12, 2009 | RIM BlackBerry Pearl Smartphone
Blackberry pearl
the only thing that you can do for this error message is to reload the operating system on the blackberry. You have to have the blackberry desktop manager installed on your computer first. Once the program is installed then perform the following
To run Application Loader on your computer, follow these steps:
  1. Connect the handheld to the computer (insert the handheld in the cradle or connect directly by USB cable).
  2. Open the BlackBerry Desktop Manager.
    • Note: Click Start, Programs, BlackBerry, Desktop Manager.
  3. Verify that a pop-up window appears when the handheld is recognized.
  4. Click Application Loader if the pop-up window does not appear.
  5. Click Update Now.
    • Note: (This option only appears if new device software is available).
  6. Click Next to open the 'Handheld Application Selection' window.
    • Each application lists (along with its file size) with a check box and an 'Action' item.
  7. Review the following information about items that appear in the 'Action' column:
    • Install: Appears when an application is not present on the handheld.
      • The application loads on the handheld.
    • Update: Appears when the application version on the handheld is older than the version available with the Application Loader tool.
      • The most recent version of the application loads on the handheld.
    • None: Appears when the application version on the handheld is the same as the version available with the Application Loader tool.
      • The application does not change on the handheld.
    • Downgrade: Appears when the application version on the handheld is more recent than the version available with the Application Loader tool.
      • The older version of the application loads on the handheld.
    • Remove: Appears when a check box is cleared beside an application and that application was already present on the handheld.
      • The application is removed from the handheld.
    • Note: For more information on a particular application, select the application, then click Details. The handheld’s standard system software is also listed in the 'Handheld Application Selection' window. The software must be loaded on the handheld. The check box cannot be cleared.
  8. Click Next.< been have selections all>
    • The 'Application Data Backup' window appears.
  9. Verify that the first option is selected by default.
    • Note: This option automatically backs up handheld applications and data. Data restores after the handheld software reloads.
  10. Click Next.
  11. Click Finish when asummary window appears.
    • The actions that occur during the loading process appear.
  12. Verify that the handheld resets.
    • Note: This process may take a few minutes.
  13. Click Close to return to the Desktop Manager.
  14. Verify that the Application Loader indicates whether or not the process is successful.
    • Note: If the loading process is not successful, verify that the handheld is connected to computer properly. Repeat the above procedure if there was a connection error.
Oct 21, 2008 | RIM BlackBerry Pearl Smartphone
Facebook Social Network Logo
19 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
