Question about Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5)
Dynex 8 port 10/100 switch not working
Bought new switch to help our home network have better connections. Now I did not want to get this one but my wife swore up and down that this one was cheap and should work just fine. Well i know cheap never works well. Now I have spent money on a worthless piece of **** until I can find a fix for the switch. And if I cant I have to get another one and now the one I want. Does anyone have a fix for this.
  • Mike Blyth May 11, 2010
    If you would like advice, I think you will need to give some details. What are you trying to do and what is not working? Does the old switch still work? Basic switches are very simple on the outside, and there is usually nothing you can do to make them work right or wrong, so if the old switch works but the new one does not (when installed just the same way) then most likely the switch is just bad and should be exchanged. However, if the old one no longer works either, then a network configuration has probably changed.
SOURCE: my dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Posted on Apr 27, 2009
  • 143 Answers
SOURCE: dynex 4 port hub xbox 360 IP address error
Here is a link to their Support site: Select "Troubleshooting/Connection" errors page. On the LEFT, select "Network Help". That should put you in the area you need.
Posted on Jun 12, 2009
  • 17 Answers
SOURCE: lost connection between switch and hub - LED flashes every 5 secs
You say you have the same problem when you connect the cable directly from router to laptop, so it apparently is not a hub problem. That leaves the router and the cable. You're fortunate in having a working system on the other port. Why not try swapping pieces to see which is the failed piece? For example, what if you swap the ports for the cables? If it's a router problem, then the "bad" cable should work when in the other port. What if you swap cables? That would reveal a bad cable. Finally, swapping computers would show a computer configuration problem, such as the connection not being set to automatic.
Posted on Sep 26, 2009
  • 27725 Answers
SOURCE: I just bought a dynex
maybe you need to configure this ethernet switch or it is a password problem i have used a ethernet splitter switch to use two connect 2 computers before purchasing a router which needed to be configured
hope this helps
Posted on Sep 03, 2010
  • 97 Answers
SOURCE: 1 connected ethernet cable from
If your trying to use this to share an internet connection.. sorry to say but it's not going to happen. The hub that you purchased will not handle the DHCP settings that need to be processed to share an internet connection.
Best advice... go back to Best Buy and smack the agent that sold you this and get a router instead. :D That's what you're needing to share your connection.
Posted on Oct 23, 2010
Can a dynex DX-ESW5 act as a print server?
No. You need a router to set / obtain an IP or connect it directly to the computer RS232 serial port. No network required, but is old school and may be difficult. Specially with MAC. You are better off getting a new router.
Jan 29, 2013 | Dynex Dx-esw5 10/100 Fast Ethernet Switch...
I bought a new pc, and installed win7 on it. but when i connect it to my linksys sd208, it says unidentified network. what seems to be the problem. thanks
this is a default check that windows does when a new network is detected "wireless or wired"
you must select the type of network this device is connecting too(public/private/home). for the most part you would select home.
do you get on the internet after choosing one? as either way you should be on the internet
hope this helps
Don't forget to vote for me
Thank You
Jul 18, 2011 | Linksys SD208 8-Port Ethernet Switch...
I have a dynex 8 port gigabit ethernet switch. I see 8 ports but do not see a port to put the incoming ethernet wire. I put it in port 1 and put an outbound in port 2 but cannot connect to the internet.
Connections should go.Main internet to router,then from router to dynex switch,then to pc or pcs.
There is no main internet ethernet port, as this is just a switch.You need a Router before the dynex switch.
Apr 08, 2011 | Dynex Computers & Internet
I just bought a dynex ethernet switch so that my daughter can plug her laptop into it and access the internet. I have a dsl modem connected to the switch. i have the switch connected to my desktop. I...
hope this helps
Sep 03, 2010 | Dynex 5 Port 10/100 Ethernet Switch...
I just bought my DYNEX 4-Port 10MBPS Hub. My PC and PS3 are attached to the Hub. Problem is only one work at a time. When I attach the secound one the green light is flicking real fast. As per manual...
A "Network Hub" is not a good device for connecting to a network. Collision is the most common problem with this device. Since you said that the device is new, maybe you can return it to the shop you bought and buy a "4 port Network Switch".
What the difference is that a hub transfers all the data that comes in one port to all the other ports. But the switch can decide destination of the incoming data. So, when the hub is sending data to a device, that device has to know whether or not to accept the data. This doesn't happen here in your case. So, better buy a "Network Switch". They both look alike and price difference is also not that high.
Aug 19, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
File sharing isn't happening
You need to go to control panel and into system, Click on teh Computer name tab and give each computer it's own name if it doesn't have one already. Then click on the change button and give your workgroup a name. Make all computers part of the same workgroup.
Oct 04, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
4 port USB hub not working...
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Jun 23, 2009 | Dynex 4-Port USB 2.0 Hub
Dynex 4 port hub xbox 360 IP address error
Jun 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Dynex ESW5 connecting PC and Mac
after hooking it up only one computer has internet
Apr 13, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5) Logo
250 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
