Question about Canon BubbleJet i560 InkJet Printer
Paper does not connect with drive when printing requires multable eg .up to ten pages
6310 problems
You have not really provided enough information to properly answer your query. However, a couple of things to check. Did you set the right page size when printing? Was the size of the item being printed able to fit on the paper size chosen? Finally, did you ensure the page format was correct - eg: as in a landscape shaped original on to perhaps a portrait shaped paper?
Jul 27, 2014 | HP Officejet 6310 All-In-One InkJet...
Tip
HOW TO GET THE BEST DIGITAL PRINTS...
Printing a photo but not getting it upto your expectation.....?? No worries just fiddle a little bit
with the printing options and keep in mind some important points that I am going to tell you....it will help:
1) RESOLUTION OF THE IMAGE TO BE PRINTED... Always keep in mind while printing a digital
printout that the resolution should be best fitted i.e. of the original photo.... if you stretch A photo too
much or squeeze you might not get the desired result. It depends upon the DPI i.e
dots per inch that appear on the paper in the snap that you print. To get a quality print you must
make sure to select proper dpi for an image in printing. Eg. for printing a snap of 300 dpi you must choose
the image resolution as 600 dpi, but in case of professionally required image quality you can select upto 24oo dpi.
2) PRINTING PAPER ... Make sure that the paper you are using is suitable for the ink and the printer that
you are using. Certain printers specially design Photo Paper suitable for the ink used in them for eg. HP printers
do have Hp photo papers to give a good quality of image.
3) SETTINGS IN THE PRINTER... You can adjust the image quality that you want by clicking on the
Properties Option in the printer dialog box that opens when you give a print command. for eg. you can select
Economy mode for saving the ink (but this will not give a good quality image as colors to will be low),
or you can use the Bes option, as suitable for you...
So next time you Print a photo or snap of yourself make sure to remember these points and have fun.....
Good Luck!!
on Apr 08, 2010 | Office Equipment & Supplies
Tip
HOW TO PRINT ON BOTH THE SIDES OF A PAPER
Its very simple to print on both the sides of a paper. If your printer is the one with Duplex Printing, then
just open the print dialog box by clicking on PRINT in the file menu of any document.
Now click on the Properties
Click on the check box (small box given along any option, where a tick appears, when clicked)
present at the side of "click on both the sides", and click OK.... and the paper is printed on both the sides.
BUT EVEN IF YOU DO NOT HAVE A DUPLEX PRINTER, THEN YOU CAN DO THAT
MANUALLY AS WELL.....wanna know how....its very simple, have a look below......:
Once you open the Print dialog box, just on the left hand side there are options given
to select for the type of printing you want.....eg. All Pages, Pages... etc. click on Pages and enter the nos. in
odd series i.e. 1,3,5,7,9.... once this printing is over now turn the sides of the pages and place it in the tray
and enter the page nos. 2,4,6,8,10 where you enterd the odd pages. Simple you will get printouts 2 at the back
of 1 and 4 at the back of 3......is'nt it simple....... give it a try and go on & save paper....
Good Luck!!
HP officejet pro 7680 print settings for iron on transfers
as a paper profile when loading use a paper that is nearest to the paper type being printed- EG- plastic sheets would become Vinyl paper/ transparency or banner profile.#
alternatively go to HP website and then to paper profiles and download the ICC profiles required follow the user manual to install to printer.
Jan 17, 2014 | HP OfficeJet Office Equipment & Supplies
It won't print photos correctly because it only prints part of the photos
While this may be a mechanical fault, and if so a service call is going to be required to fix it, it can frequently be caused by software settings for the printer drivers or for the software being used at the time the photo is being printed.
When you select print from the software the usual response is for the printer driver's dialog box to appear. Within that box is a radio button which is usually marked "Page Setup". Selecting that button will access settings for various paper types [which can effect the problem you are having if the wrong one is high-lighted] as well as various other feature settings which can effect the printers output.
The support website for your specific printer should have information on what settings to change to realize desired results.
In software, like Photoshop for instance, settings for image size can effect the printed end result if the settings are a mismatch between photo size selected and the photo paper being used [unless there is a "fit to paper" option checked in the aforementioned printer driver page setup dialog box]. Like having those settings set to print an eight by ten print on four by six paper, for example. These settings should be checked to make sure your selected photo print size matches the paper you are printing on.
Hope that helps.
Feb 04, 2010 | HP Photosmart C3180 All-In-One InkJet...
Laserjet 1200 prints off the edge off the page - please help
do you have the correct paper setting, drivers, etc ...
does it do that in all programs or gist in one or eg. gist for text?
on all paper sizes?
what if you load the max paper size sheets? it shouldn't be able to do that then.
what ratio do you have in the settings? make sure it's 100%
what if you make the print object smaller?
Feb 22, 2009 | HP LaserJet 1200n Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Valid page names message driving me nuts
when printing specific pages the valid range is in this format 1,3,5,7,9,11 etc or if printing even numbers 2,4,6,8 etc or if printing specific pages 1,5,17,21,23,24,32 etc
what makes it a valid range is the comma between the numbers, no spacing and no full stop at the end
to further add confusion
when printing all of the pages just click all pages and it will print one sided all of the pages so no numbering is required
however if you want to save paper and reduce the size of the document
click pages 1,3,5,7,9,11,13 through to ,57
print those pages then turn them all around and upside down reinsert in the printer
now select pages 2,4,6,8 through to ,58 and print
that will give you printed data on each side of the paper in the correct page number order
to get to know how to reinsert the paper test with a print page 1 then reinsert and print page 2 to make sure that you have turned the paper the right way round
Jun 28, 2017 | Samsung ML-2510 Laser Printer
Actually for a HP deskjet 990cxi
Alignment:
1. Turn on the HP DeskJet.
5. Press Copies .
Jun 03, 2008 | HP DeskJet 940c InkJet Printer
Toshiba eStudio232
Make sure store to e-file is not picked on the print job page on the printer properties. Also make sure the paper size of what your trying to print is available in the machine( eg print job is A5 paper etc)
Oct 04, 2007 | Office Equipment & Supplies
Canon BubbleJet i560 InkJet Printer Logo
13 people viewed this question
old marine
old marine
