Question about Olympus FE-170 Digital Camera
Camera's stuck! i had it on and took a few pictures, then when i looked back at it, the lense was stuck out, and the scren was black. i've tried turning it off but it won't go! an orange light just blinks but nothing happens and i've tried to charge the battery but it's not helping!!!
    President:
  • 2,761 Answers
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
    President:
  • 1,197 Answers
If ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Oct 25, 2009
I have a D70 with 26,000 shutter releases. Just recently it stopped composing pictures. In other words, I can take a pic just fine, but the playback is black, it saves to the CF card, and if I look at on...
Remove the lens and fire off a few shots while looking inside. Check to see if the mirror flips up out of the way and that the shutter opens exposing the sensor.
Oct 09, 2011 | Nikon D70s Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Lense won't close
Does it make a noise when trying to close? Does the lens zoom ok or is it just stuck firm?
Possible solution and/or email help available in "THE ONLY WAY I KNOW HOW..." In tips & tricks. Thanks
Apr 12, 2009 | Fuji FinePix F460 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My camera's display is black when I try to take a picture, and all the pictures I take are all black. How do I fix this problem?
Your digital signal processor is bad or your lense shutter is stuck on the inside. A stuck lense can be fixed by replacing the lense barrel. Check out Camera Shy Anna on Ebay stores. They can fix your digital camera.
Nov 25, 2008 | Cameras
Flash
I gave the lense part of the camara a moderate slap, and the camara has worked fine since. looks like a lot of people have the same problem. Most of the people call it black screen problem. the shutter gets stuck. Tap it a few times on the side of the lense part of the camara moving it from bright to dark objects back and forth.
good luck.
Aug 18, 2008 | Nikon Coolpix S4 Digital Camera
Yep. another lens stuck.
it depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Aug 16, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Olympus FE-170 Digital Camera Logo
189 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
