Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Water does not seem to pump through the jets to wash the dishes. fills and drains fine.
  • 161 Answers
Go to the store and get some jet-wash. I think that is what its called, but its in the same area as the dish detergent and it is for cleaning the dishwasher. Run a cycle through and this may help.
Posted on Sep 26, 2009
Water fills the bottom of dishwasher, lower spray arm still seems to turn/spray but no movement or water coming out of uppoer spray arm. We took apart the lines to see if there was blockage -- none.
If there is no blockage, your pump may need to be rebuilt or replaced. If your machine uses a solenoid valve to control weather the pump is washing or draining. The drain valve may be stuck somewhat open, diverting wash water down the drain. Or the wash valve may be not opening fully. Different machines work in different ways.
Nov 09, 2013 | Dishwashers
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dishwasher fills and makes some sound but no water is sprayed. When canceled the pump drains the dish washer. Is there a separate pump that pumps during the wash cycle?
It could be that the jet holes in the rotor arms are blocked.
The arms are easy to remove so take them out and check out the jets.
Also take out the filter in the bottom of the machine and check that it is clear.
Sep 26, 2010 | Whirlpool 24 in. DU920QWD Built-in...
Not washing dishes
check the water make sure the water is correct. fill water drain water and circulation water.
fill water comes from under sink, drain water from drain pump and drain hose ,circulation pump controls the water washing. let me know if this helps.
Mar 06, 2010 | Dishwashers
I have soap build up in the dishwasher. The dishes aren't getting completly clean. Ran load today twice and they didn't look any better.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Unclean dishes food particles left on glasses
Sep 11, 2009 | Dishwashers
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
Sep 11, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Fills with water and drains will not run to wash dishes
The main water pump is not working. A repair will be pricey. it may be best to get a new dishwasher
Apr 21, 2009 | Dishwashers
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
162 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
