INNOVATEK INNO TOUCH MP3 PLAYER IMPROPERLY CALIBRATED TOUCH SCREEN AND I CAN'T THEREFORE TOUCH THE CALIBRATE BUTTON
Sheesh I just got two of the inno touchscreens and I can't get mine to turn on even after charging it over night only way it will come on is to hook it up into the computer or wall then it comes up the icons then straight to the blue screen to calabrate it I assume it will do the two top sides then gets stuck at the bottom left side and won't go any further, HELP ME I am ready to take these idiots for a ride
Posted on Sep 29, 2011
Inno touch turn the power on ,but cannot open the program
Posted on Jan 11, 2010
My V touch screen wont react when i touch it
If you can, go to: settings ---> calibrate. Calibrate the screen by pressing the icon that appears in the corners. If you can't go to settings try the reset button on the back. If that does not work format the player.
Sep 13, 2013 | Visual Land V-Touch Digital Media Player
My touchscreen doesnt work on my Ikasu 8gb media player for some reason anyone know how I can fix this?
If the touch screen does not work, it may be because it is out of calibration.
You can go into settings and navigate using the buttons to recalibrate the touchscreen.
Slide the on/off slider briefly. It should give you a menu.
Use the - button to scroll down to calibrate.
Push the M button
This gives the calibration screen.
Press the small square that appears in each corner, and finally in the center.
This should give you the touch screen, hopefully working.
There is a manual and other information here.
www.fascin8.co.uk/f8/ikasu/mp4-players/8gb-touch-71939#tutorial
Jan 31, 2011 | Audio Players & Recorders
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Feb 04, 2010 | Sony E-reader Portable E-book MP3 Player
600 soft touch e-reader says it needs calibrating? what does this mean
This error indicates that an issue occurred during the calibration procedure or the Touch screen doesn't function properly. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process. 2. Tap the center of each "X" that appears on the screen. 3. When "Touch Panel calibration completed" is displayed, click "OK".
Feb 03, 2010 | Sony E-reader Portable E-book MP3 Player
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Coby mp3 player touchscreen wont work
to fix this problem go bak to calibrate and the screen will go blue and in the corners you will see a cross hit the crosses in order in 3 sec or less and the mp3 will go back to touch screen! if it works let me knoow via email gaudettemichael3@gmail.com
Dec 25, 2009 | Audio Players & Recorders
I bought a coby mp822-4g and i accidently clicked on calibrate now its not a touch screen
you may have touched the screen and changed the calibration try navigating to the calibration menu with your buttons and recalibrating it.
Sep 25, 2009 | Audio Players & Recorders
Touch screen will not properly calibrate
Under settings, go to "system" and go to "touch calibration" and see if you can fix it there.
May 30, 2009 | Sylvania SMPK8854 Digital Media Player
Mp3 player messed up
   Please find reset button which will present in a hole. insert some kind of pin or any thing els in the hole to press it, afterwards it work fine again.
Thanks for using fixya.
May 13, 2009 | Audio Players & Recorders
How do You download video into the Innovatek Inno - 89 MP4 Player? Please help
I have the player for my brother for christmas and had to pre-load it for him.
You have to download a program called AMV video converter.
This particular mp4 player only uses .amv movie files.
Some use .amv and .mtv but this one uses .amv and you can convert almost any movie file .mpg, .mpeg, .avi, ect... into .amv
Then just drag and drop it and play!.
Make sure you check all settings and make the video conversion big enough to see on the player.
God Bless and good luck!
Knowledge
Apr 22, 2009 | Audio Players & Recorders
876 people viewed this question
 Grubhead
Grubhead
