Question about Maytag PYE2300AY Electric Dryer
Dryer will not turn on. It was working fine this morning and then tonoight nothing.
  • Maytag Master
  • 1,606 Answers
You probably have a shorted thermal fuse . This is a small thermostat , located on the element housing , on the right side . Lift the top by inserting a putty knife , about 2 inches from both sides , on the front , and lift top . The element is at the rear , on the left . @ white wires run to the thermal fuse , on the box . Part number LA-1053 . Instructions come with the part .
Posted on Sep 26, 2009
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Oct 18, 2010 | Indesit W 123 Front Load Washer
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
My dryer was working fine this morning i tried to dtart it anddid nothing no sound nothing is just not starting i already check the breakers
heatman101
Sep 06, 2010 | Whirlpool LER3624JQ Electric Dryer
Last night I dried multiple loads of laundry . . . the dryer worked fine. This morning when I pressed the button to turn it on nothing happened. The control panel is completely blank, as if the dryer is...
heatman101
Aug 24, 2010 | Kenmore Elite HE4 Electric Dryer
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Maytag dryer quit working
check your braker turn off then back on
Dec 12, 2008 | Dryers
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Maytag PYE2300AY Electric Dryer Logo
437 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
