Question about Frigidaire GLEQ2152ES Electric Dryer
Doesn't start my dryer wont start. NOthing electric works and i can't find the fuse. Does anybody know where the fuse is? Is a 2005 frigidaire gleq2152eso. Thank you :)
    President:
  • Frigidaire Master
  • 1,922 Answers
First are you sure you have power to the unit?then if you do you could have an open neutral connection in the unit, the only fuse in these could be an electronic fuse on the control pad to protect the electronics on the circuit board
Posted on Sep 26, 2009
Model # fex831fso stackable frigidaire dryer wont start just humms
you may have applied high voltage/power or in appropiet current flowing through the conductors
Feb 16, 2016 | Frigidaire Washing Machines
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dryer wont start but the timer cliicks frigdiare dryer
It sounds like the thermal fuse. Without knowing model number I cant tell you exactly. Depending on how you access it. Near the blower housing you will see a little white sliver fuse ot a round fuse with two wires running to it. The one next to it has 4 wires running to it. Disconnect power before opening the dryer... Take a meter and see if it has continuity. If not its bad. Anything further please feel free to reply.
Jul 10, 2010 | Frigidaire GLER642A Electric Dryer
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
I have a Maytag Neptune Electric dryer. It won't
Try to plug something else in the same outlet, if it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers. Electric dryers should have the wiring checked at the terminal block to make sure that the connection is good, or to verify that the connection is burnt out.
If the power is there, you will have to check the door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Thanks for using fixya
Jun 03, 2010 | Maytag Dryers
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Sep 06, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire model # FDE336RES2 Wont turn on.
The fuse is located on the rear wall upper right hand corner. To get to it you must bust dat dryer down. HERES HOW
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2009 | Frigidaire FGR341AC Electric Dryer
Dryer wont run
The fuse is located on the rear bulkhead upper right hand side. Clean the dryer out open all vents check slides and rear bearing.
Dec 14, 2008 | Frigidaire GLER331A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
249 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
