Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Wireless signal stops working after some period of time
I come home each evening and try to connect to my D-Link WBR-2310 but my laptop does not detect the signal until I reboot the WBR-2310. Once it reboots, it works fine. Then the next day, same thing.
My unit is hardware version A1. This started a couple weeks ago when I upgraded the firmware to version 1.05.
    Novelist:
    Habit-Forming:
  • D-Link Expert
  • 199 Answers
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Posted on Jan 06, 2017
Nowuser
  • 56 Answers
SOURCE: wbr-2310 d-link
Follow these steps:
1.Type 192.168.1.1 in Internet Explorer.
2.You might have to put Admin password to access the router which is usually admin and password field blank.
3.Go to wireless setting and change the password.
Posted on Dec 25, 2007
peglegcards
  • 89 Answers
SOURCE: D LINK 2310 SOFTWARE
Hello, Go to dlink.com and do a search for you model number. You should be able to find the software and download free. Hope this helps..
Posted on Mar 22, 2008
dante777
  • 623 Answers
SOURCE: cant install D-Link WBR-2310 on vista
The error message seems very common when it comes to software installation on a Vista machine. It very likely indicates that the software you are trying to install is not working correctly with Windows Vista.
The latest version for the 2310 model "Quick Router Setup" software is 4.10. (You can find that here.) If you tried to install an older version, completely uninstall it before trying to install the latest one.
Also check which revision of the router you have here.
In general: If you are trying to install the D-Link software on your laptop - you don't have to do that. These softwares usually make your initial setup easier, but you don't gain any advantages on the long run.You can configure your router simply from a web interface. Open a browser, type 192.168.0.1 in the address bar. The default username is "admin" and the password is blank (nothing),
If you need more information, you can go to the D-Link webpage and also download a manual from there (look in the left pane)
Posted on Apr 04, 2009
SOURCE: installation problem of D-link wbr- 2310 wireless router
plug everything in first and just run the router, that's what i did and then set up the disk later
you dont really need it personally
Posted on May 28, 2009
kamal1984
  • 1383 Answers
SOURCE: dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Posted on Jul 23, 2009
I have a WBR 2310 I am trying to set up as a extender. Picking up a hotspot ssid dlink. Signal is weak and sometimes usable. Want to strengthen the signal to use with my home system. I have tried several...
More likely it has to do with the channel and how it is is from router. If you have a smartphone download app Wifi Analyzer and see which channels are interfering. Here is the way to log on to your extender and intructions. https://www.wikihow.com/Set-Up-a-D-Link-WBR-2310-Wireless-Router
Oct 07, 2017 | D-Link RangeBooster G WBR-2310 Wireless...
Configure d-link wbr 2310 and now wont connect
Hi mech_warrior,
Press the reset button of the d-link router for 30 seconds, unplug and plug the power cord.
MAC cloning is used for Cable ISP configuration but that should not affect the router's functionality (odd router behavior) ;-)
That should do it!
Angel
Jul 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Low wireless signal wbr 2310 on signal strength
Hi Thanks for your question.
My advice would be to consider moving your router to different place. Put it a bit higher. There's also a lot of products like bigger antennas and wireless range expanders that you could consider buying. Here's link to some of the products so you can have a look what I mean---> click hear You could also try low cost home ways to boost your signal like- Attach a bit of aluminum foil to the router antenna. Position the foil so that the signal bounces off the foil in the direction of your computer. I hope this was helpful. Good Luck
May 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
My Dell laptop does not connect easily to d-link WBR 2310 router
2 wireless laptops are connecting. that means the router must be working properly. Only 1 laptop is not connecting.
Try to change the wireless channel on the router.
For this you will need to open the set up page of the router.
Is there any computer connected to the router ? If not then you will need to connect the computer to the router and open the set up page. Under wireless settings try to change the wireless channel on the router and see if that works.
Apr 16, 2010 | D-Link Computers & Internet
Wbr-2310 wireless stops resonding randomly.
unplug for 10 seconds, plug back in. These units to tend to get a stat build up charge
Nov 08, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot connect to new wi-fi signals
Try removing all past connections , go to control panel , delete all your old settings and start new.
Apr 11, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Installation problem of D-link wbr- 2310 wireless router
Feb 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have a D Link WBR 2310 router. I had it set up for wireless network on my home laptop. It was always configured for immediate access (no pwd required), secured with wpa. I try to connect with my work...
did you reset to factory defaults or just unplug the router?  If you hit the reset button, you'll have to go in and set everything back up.   Have you tried to connect via webbrowser connected to the router from your home computer?  go to 192.168.0.1 and see if you can connect to the router to see what's going on.
Dec 17, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
142 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
